Old 11-03-2002, 05:53 AM
skitzophrenik skitzophrenik is offline
Question What type of batteries are best to use?
Sup yall,
I just got a quick question about the Bit Char-G controllers. Is it possible to use re-chargeable batteries in them? And if so, are there any specific types that are compatible or I should avoid? I just dont want to buy some that end up not working...
later
Old 11-04-2002, 11:41 AM
lunatic7 lunatic7 is offline
I have been using nimh recharable batts in my controllers for both my ZZ and bcg clones. no probs to report.
Old 11-15-2002, 10:52 PM
thanx for the info, man
Old 11-16-2002, 12:49 AM
Sniper596's Avatar
Sniper596 Sniper596 is offline
I'm 1337 r/c'er :)
I'm running with some nimh aa batteries in my controller, gotta love the life of the batteries, one week to two weeks on regular use before you really need to replace them with charged ones.
Old 11-17-2002, 11:35 PM
keith20's Avatar
keith20 keith20 is offline
If you don't want nimh, try Rayovac rechargable alkaline. I think they have a little more voltage. I run them in my Bit, My ZZ, and my clones, with no problems.
Old 11-18-2002, 06:35 AM
Ok, I'm just wondering why it says in the microsizer manual to not use Nicd batteries and to only use alkaline. Are nicd and nimh the same or similar?
Old 11-18-2002, 06:52 AM
SuperShot's Avatar
SuperShot SuperShot is offline
Probably because NiMh and NiCd batteries only give 1.2 V each, Whereas Alkaline batteries are 1.5V. To charge a battery, you need somewhat higher voltage than the battery you are charging, and NiCd/NiMh might not give enough. The Rayovac batteries are rechargeable Alkalines, and give 1.5V, so I would recommend those.
Has anyone tested the range of the car with NiCd vs Alkaline? Presumably, the range should drop off with lower voltage batteries. (Mod suggestion: 3X NiMh batteries in controller for a total of 3.6 V. Might burn out the controller and/or car, but would be fun to test if you have a clone to fry)
Old 11-18-2002, 03:19 PM
Sniper596's Avatar
I'm 1337 r/c'er :)
i dunno, i get around 15-30 feet range with nimh depending on where i drive and if i stand up or not.
rechargeable batteries kasper01001 XMODS 25 02-26-2004 07:29 PM
rechargeable batteries Chrisman222 XMODS 6 11-16-2003 09:51 PM
Rechargeable Batteries? Roadkill Plantraco Desktop Rover 4 02-15-2003 02:16 PM
Rechargeable Batteries in Controller kitkat Bit Char-G / MicroSizers 10 01-09-2003 12:51 PM
Rechargeable batteries in Tx? Need4Speed210 Bit Char-G / MicroSizers 4 10-07-2002 09:30 AM
