Old 10-07-2002, 12:02 AM
Need4Speed210's Avatar
Need4Speed210 Need4Speed210 is offline
I want a Lambo bit!
Question Rechargeable batteries in Tx?
hello, I was just reading the online MicroSizers manual, and stumbled accross a line that said 'install fresh Alkaline batteries,..... do NOT install rechargeable batteries'. Can anyone explain why/ if this is true? Id really like to use the NiMH or NiCADs I have but If this is true I guess Ill be constantly buying Alkalines . Thx for any input in advance.
Old 10-07-2002, 02:40 AM
Bus Driver!
Have seen this queston on this and other micro RC car site. That same worrding is in most all of the manuals for the bulk of the micro cars.
This is my own oppion for no recharagable and I can be wrong.
Two reason:
1) Lower voltage limit. There is a chip from Realtek inside that has a operaing range of 2.2v to 5.0 volts. With two recharagable your getting 2.5v not 3.0 as with two Alk. Being 0.3volts about the bottom limit is a bit thin to have but 0.7 is much better!
2) Limiting factor for recharging. Or basically a Alk can only produce only so much current around 450ma and no more while a nicad or other type can put out 1.6amp or 1600ma. To regulate that for charging for any power source would take more costly componets and designed. By using a Alk and it max draw limit would allow a simpler designed. Since you charge a bat with current. Too little current and it takes forever to charge. Too much current and you have a bomb on your hands!
Hope that helped.
Old 10-07-2002, 02:46 AM
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
hmm...i always use Lithium batteries...although a little more expensive...the power of those things are awsome
Old 10-07-2002, 07:07 AM
killboy's Avatar
killboy killboy is offline
We run NiMH's in our remotes and they work great. Take it from someone who has actually tried both.
Layda,
Darryl
Old 10-07-2002, 09:30 AM
I want a Lambo bit!
thx for the answers guys. After thinking about it, NiMHs and NiCADs do have a lower voltage, so that would be a no no. Can you buy rechargeable lithiums? about how much $$$? and what about rechargeable alkalines?.........I just really......really hate normal alkaline batteries ....thx
Rechargeable Batteries?? mixedgangsta XMODS 6 07-31-2006 09:52 AM
rechargeable batteries kasper01001 XMODS 25 02-26-2004 07:29 PM
rechargeable batteries Chrisman222 XMODS 6 11-16-2003 09:51 PM
Rechargeable Batteries? Roadkill Plantraco Desktop Rover 4 02-15-2003 02:16 PM
Rechargeable Batteries in Controller kitkat Bit Char-G / MicroSizers 10 01-09-2003 12:51 PM
