Old 01-21-2003, 09:21 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
Nakamichi racer - quick review
fast in normal mode, faster in turbo mode, package says it charges for 90 seconds and runs for 9 minutes, i got a 20 second charge and a 2 minute runtime. its not too loud, body loks good (a bit big) body is not of a real vehicle (that i can tell) pcb is twice the size of normal cars. dual cell 80mha 1/4 AAA batts (shorter than stock ms batts) cool rims front rims are a bit loose and you cant adjust the steering pins (by pushing them into the knuckles) doesnt turn left (right wheel turns left wheel does not when pressing left steer) when right turn is pressed both wheels turn all the way (while standing still on my table) i am trying to get the guy i bought it from through e-mail to see what my options are about this racer. if i can return it i will, if i can get another in exchange that is fair (thats what i want) otherwise, if im stuck with it, ill be doing a pcb swap onto a MS chassis (clone) and let u all know how it turns out. also the chassis isnt much different than the MS chassis, same overall length, almost as wide (its a tad wider) tabs are the same width. if i think of more ill report back.
Old 01-21-2003, 11:17 PM
shocon2k
Unless you mean you're swapping a clone PCB into an MS, then you're wrong about an MS being a clone.
Microsizers are made by Hobbico, aka Tomy. They're not a clone, they're the real deal.
Old 01-21-2003, 11:23 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
yes, thank you for clearing that up, b/c apperantly im a retard.. no actually i knew that and you knew what i meant.. but thanks for trying to make me look dumb, i just hope in all your efforts to belittle people that you find true happiness.
$5.99 Nakamichi Racer!! Nefarious Bit Char-G / MicroSizers 24 02-01-2003 02:41 PM
Nakamichi Racer Wanted payaso For Sale/Trade 37 01-31-2003 02:21 AM
Nakamichi Racer Review Aaronmamo Bit Char-G / MicroSizers 2 01-21-2003 05:15 AM
Want a Nakamichi Racer? MST3KPIMP Bit Char-G / MicroSizers 17 01-09-2003 04:14 PM
Nakamichi N Racer Bit Char Bloke Bit Char-G Mods and Projects 0 11-11-2002 11:59 AM
