Old 02-18-2003, 09:41 AM
scottyboyfun's Avatar
Im a cat, miow.
well if its true,sorry i doubted, its a forum and sharing is what were here for!
Nice 2 c u got a result!
What can ur controller do now?
I think I got a bit lost!
So what do u lot think?
Post it!
Old 02-18-2003, 10:02 AM
tiberius tiberius is offline
Known Prick
The TX functions as described earlier in the thread. I would like to refine the mod a bit, but I hurt my back last week. Makes it damn hard to do that kind of work. The first one will be a Rumble Claw. I may do pre-orders or mod owner’s existing Wilds. We’ll have to see how it goes. I will also be moving a week from Friday. Out of my Mother-In-Law’s basement WOOT! (Shacking up there while I had a new house built).
Old 02-20-2003, 08:34 AM
Im a cat, miow.
Ive figured out how to make a wild charg controller, both boost and action,
It is really simple,
You have to solder a wire to PIN --TURBO-- on the transmitter, then solder this to a switch, then solder the other point on the switch to ground.
When u press the switch, it will boost, and when u press ur action, it will do that!
This could be the way tiberius did his, Im not sure if this will work, but it is definitely worth trying.
I havent got a WILD controller to do it with tho.
ONLY DO THIS IF THE CHIP BELOW HAS THE SAME NO.
LOOK AT THIS PAGE
http://members.aol.com/rchelicam/microszr/microszr.htm
Post it!
Old 02-20-2003, 08:53 AM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
Sounds good to me... it looks to be a logical adjustment. It may be worth the test, could always replace the char-g if it catches on fire.
Thanks for the info and pics scottyboyfun.
Old 02-20-2003, 08:55 AM
Im a cat, miow.
I cant c ne reason why it wouldnt work, if u find it doesnt, then undo the mod straight away.
Post it!
Old 02-20-2003, 01:33 PM
Known Prick
The Wild Char-G TX uses a diffrent chipset. It is in the X2 family, but also has an F1 ("extra" channel) function. I was never able to find the datasheet for this chipset. The physical chips in the Wild TX are COB (blob like the Tomy RX chips) packages.
Booster PCB layout mcharles13 Bit Char-G Mods and Projects 0 07-26-2004 10:54 AM
in need of booster PCB!! xxspeednplayaxx ZipZaps 0 09-05-2003 11:20 AM
Best Booster PCB? r34 racer Bit Char-G / MicroSizers 9 05-07-2003 08:32 PM
picked up a black mustang and the new booster motor pack. OMG Clint ZipZaps 6 04-21-2003 09:20 PM
booster pcb sipsap Bit Char-G / MicroSizers 4 01-19-2003 10:33 PM
