Old 01-27-2003, 06:59 PM
johnrtse's Avatar
johnrtse johnrtse is offline
Really, Absolute Max Voltage for PCB?
I have heard, like everyone, that 5 volts is about it.
But, What is the most voltage that anyone here has ACTUALLY tried to pump thru a Bit or ZZ pcb- WITHOUT frying it??
The reason I ask is that I am building a dragster (thanks Ripper for the inspiration!) and want some serious power. I can build a 5 or 6 cell battery pack just as easily as a 4 cell .
My test pcb will be a ZZ board I have left over from the clone pcb swap I did on one of my ZZ- If I fry it with 5 or 6 cells, who cares?
Just wondering what people have REALLY done.
Thanks!
John
"It takes a Mopar to catch a Mopar!" - Vanishing Point
Old 01-27-2003, 07:09 PM
Canadian Bit's Avatar
Canadian Bit Canadian Bit is offline
You can't beat it.
Johnrtse, you are correct. On the Zip Zaps forum now, the first thread is about somebody's 4 cell dragster. He/she had 4.8 volts going through the PCB without wrecking it. If that can happen, try 6 volts.
My Garage: One Lamborghini Jota, Murceilago, Diablo, and a Countach.
One Ferrari Enzo.
One Porsche 911 GT2s, and 1 911 Turbo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
And 4 dozen Toyota Supras, 6 Skylines, and a Hino Blue Ribbon Bus from the Keisei Line.
Old 01-27-2003, 07:35 PM
dieselboy dieselboy is offline
Send a message via AIM to dieselboy
I belive someone has done 9 volts but that was with a LARGE motor. Isn't the 9 volts still running through the board though. Someone correct me if i'm wrong but i think its the current that would fry and board and not the voltage.
Old 01-27-2003, 07:40 PM
strider_mt2k
That's great news!
I want to use the RC controller boards with some relays to control other stuff if I can.
A big part of that is being able to run it close to 5v to operate the small relays I have.
I also have some latching circuits I can add for a push0n-push off effect.
These boards are so tiny that I could use three together to give a larger mobile platform some interesting features.
Old 01-27-2003, 07:43 PM
dabigpig's Avatar
dabigpig dabigpig is offline
i think the nine volts was triggered with a transistor
*** AMC Veteran ***
-- ^-_-^
Old 01-27-2003, 08:19 PM
it was a 9 volt battery sitting on top of the car with a large motor attatched to it. The guy said it didn't run worth **** with the motor setup he had on it, but he still have a 9 volt battery.
Old 01-27-2003, 11:17 PM
DKS's Avatar
DKS DKS is offline
I have an LXX with 4 cells and it hasnt blown yet!
driftkingshop.com
DKS 3.4 Darkside, 2 cell equipped NSX
27 MHZ
Old 01-28-2003, 06:24 AM
You can't beat it.
Oh yeah, I just forgot about that site. Just think how much he/she would need for that Bit to prevent wheelies.
One Ferrari Enzo.
One Mercedes SL600.
Two 95' Mazda RX7s.
Max voltage for PCB?? Halo179 ZipZaps Monster Truck 4 03-27-2005 12:28 PM
PCB-reached max voltage jpaustin ZipZaps 9 02-01-2003 09:39 PM
The Max Voltage!!!!! scottyboyfun Bit Char-G Mods and Projects 0 12-19-2002 07:07 PM
AC-to-DC adapter for controller gRC ZipZaps 50 11-18-2002 10:19 PM
