01-01-2004, 10:40 PM
I KNOW NOTHING!!!
neurokinetik, nice job on that body I still need to do that it's just down on the list.
Now about the glue is it just CA or is it the gel CA?
I was thinking the gel CA would help fill the gaps if any.
01-02-2004, 12:52 AM
cool, actually thought about replacing the "windows(black areas) with somethin more realistic, lighter, and reasonable than that thick plastic. That stuff is pretty thick and with the black eliminated/replaced it would be much lighter. But with the back mount on the inside of the body thats nearly impossible unless you find a different way to mount the body to the chassis.
dont know, just a thought.......
ok i have mods on it now lol
Xmods Skyline
Stage 2 motors
Foam Tires/Wheels
Headlights( they are cool, just hard on batt, reeeal hard lol so i run them at choice times)
RS Rechargables
*custom* antenna(still tweaking, need wiring)
01-02-2004, 08:44 AM
It is the thick CA. I guess you could call it "Gel". It definitely stays where you put it, for the most part.
01-02-2004, 10:48 AM
What is CA?
01-02-2004, 03:06 PM
CyanoAcrylate Ester. Same ingredient as Krazy Glue, which is basically what this stuff is, but in a thicker form that stays where you put it, gives you more time to position pieces, and fills gaps in seams.
