Old 01-09-2004, 03:46 AM
Real Cars Suck
Gear ratios to motor performance
I just bought the ZipZap performance package for my SE.
Can anyone give some of their feedback on what gear ratios and such work best with the included motors? (Why the heck they included a slower green versus a Nitro motor.. oh wait I know, so you have to buy that stupid body kit.).
Older thread? Just point the way for the ignorant.
Old 01-10-2004, 12:28 PM
kanegs kanegs is offline
I got the same upgrade on Monday.
I was hoping the green motor would have more torque, but that doesn't seem to be the case. Ideally then it should give you longer run times, but I haven't done any testing yet to confirm that.
If you've got wide open spaces, the red gears should give you top speeds. My kitchen is barely big enough to get the car up to full speed.
The green gears are in between the blue and the red in terms of both speed and accelleration and work as a pretty good compromise.
I've noticed the the yellow motor and the blue gears have enough torque to handle short stretches of carpet (it comes in handy when I need to back up if I've driven too far).
Old 01-10-2004, 01:19 PM
charliebrown's Avatar
I'd suggest using the NX motor with the blue/green gears. With the red, it'll barely budge. The red gears are O.K. for speed, but the car is so heavy, with that setup you'll have a big loss in torque. On the old ZipZap, the NX motor and red gears should kick ***.
Chuckster...
Old 01-10-2004, 11:29 PM
Real Cars Suck
Doesnt come with the NX motor. You have to buy that IntialD car set.
I have found a good compromise with the yellow motor and green gears. Though really short runtimes.
The orange motor with red cant reach top speed (even if I let it go a distance). It does the best so far with the blue gears.
Oh yes, I also was hoping for more torque out of that green. It failed miserably to provide this, It does seem to give slightly more runtime, but the "need for speed" is so lacking in this.
Hmm before I jump on a expensive phast or a 4.2pro I think I will fet mine.
Old 01-11-2004, 06:10 PM
From: http://support.radioshack.com//suppo.../zz-motors.htm
Code:
					Rated
	No-load	Rated	Oper.		Voltage	Mech.	Weight	Efficiency	Starting	No-load	Stall	Torque
	Speed	Voltage	Voltage	Mech.	Max	Max	Max	Max	Voltage	Current	Current	Max
	RPM	V (DC)	V (DC)	H	V (DC)	H	G	nM %	V (DC)	mA	mA	mNm
Blue	10,000	1.3	1.3-1.6	10	3.0	>12	1.27	11%	0.8	< 25	< 70	0.07
	± 2000
Green	16,000	1.3	1.3-1.6	10	3.0	>12	1.27	20%	0.6	< 35	< 150	0.13
	± 2000
Red	22,000	1.3	1.3-1.6	10	3.0	>12	1.27	38%	0.6	< 50	< 265	0.147
	± 2000
Yellow	24,000	1.3	1.3-1.6	10	3.0	>12	1.27	37.21%	0.6	< 50	< 285	0.159
	± 2000
Notice that the yellow motor has so much more torque.
Monster Truck and Upgrade Gear Ratios? rfnagel ZipZaps Monster Truck 33 02-16-2005 09:44 PM
Equation for scale speed and gear ratios. Zephyranthes Bit Char-G / MicroSizers 0 02-10-2003 07:34 PM
what are the gear ratios for the zz tune up kit isk8blind Bit Char-G / MicroSizers 2 01-04-2003 07:30 PM
Gear ratios for new motors Ganpachi Wild Char-G 1 12-24-2002 12:45 PM
Wheels and Gear Ratios NMT RACER Bit Char-G / MicroSizers 5 10-08-2002 06:55 PM
