Old 01-03-2004, 06:23 PM
ax0n
Differential Fun - Quick Change between RWD/AWD in the paddocks!
Well, I bought the AWD kit specifically for the rear ball differential. Kind of disgruntled with the fact that LSD did almost nothing for my steering/traction issue, I played with the differentials a bit. I remember people here saying you can loosen the screws and tighten them to change the ball diff's characteristics.
I found that you can loosen each of the 3 screws about a whole turn (maybe a little more, but definitely not 2 whole turns) and end up with freewheel spinning on the back end, ghetto FWD. That was okay, but not my style.
here's what I did.
I put the red gear diff on the back, and the red ball diff in front, exactly opposite what radio shack says to do. With the body shell off, you can get access to the differential screws one at a time, by rotating the wheels till you see a screw right near the front of the suspension. Get on it with a small screwdriver.
Make the differential really tight for a full AWD effect.
Loosen it up a lot for a more rear-biased drive with enough front wheel pull to keep the oversteer and spinouts in check
or
Loosen it further for almost pure RWD only. The fronts will still spin if you are off the ground, but with any pressure, the fronts stop and have no resistance.
Old 01-03-2004, 07:35 PM
Joey's Avatar
Joey Joey is offline
And that in no way stresses the differential(s)? Not that it sounds like it would.
Mazda Savanna RX-7
stage 2 motor | spaced wheels
Old 01-03-2004, 08:32 PM
ax0n
Gear differentials (like the stock white one and the red one that comes assembled with the front axle of the AWD kit) don't really get "stressed" because of driving. I am kind of new to R/C cars as far as differentials are concerned, so I don't know much about the ball differential other than what I've gained through some reading here and there, and my own personal experience. In real life, many limited slip differentials have friction plates, which are like clutches or brake pads, and eventually wear out after 100,000 miles or so. Once they wear out, they're not much worse than a gear differential as far as I know.
The only odd wear I'd expect to see is maybe stripping the differential screws, because you have to come at the front differential from an angle. Be careful working on the screws and you should be fine.
Old 01-04-2004, 09:51 AM
Mr BigShot Mr BigShot is offline
TinyRC PRO Modder
Ball difff ?
I have the ball diff in the rear if i just tightin it up real good it wont slip ?
Old 01-04-2004, 10:21 AM
ax0n
tighten it real good and it will be almost as good as a solid rear axle. If it's in the rear, you can get to the screws (again, one at a time, through the spokes in the wheel without removing the body shell. Tighten them snugly, not overly tight, as you might strip the differential.
Once that's done, spin one rear wheel with your finger. The other one should spin with it exactly, versus not spinning, or spinning the other direction. Note, making the rear differential lock up more will slow you down on low speed cornering, but if you can still easily oversteer (drift) through corners if you don't have AWD.
Old 01-04-2004, 03:54 PM
scott scott is offline
any one use a ball dif front & back?
The Ball Differential: LSD, USD, or LGD? Turnination Guy XMODS Parts and Hop-Ups 0 02-03-2005 01:29 AM
