11-05-2003, 11:12 PM
battery size
i was wondering what size the se batteries are in the zz se. i just want to know because most likely if I pop open the pcb ill break it . and im about to order some stuff from toyeast. and want to know if the batteries that fit in zzs fit in zz se.
11-07-2003, 01:29 AM
I took my SE apart, no big deal, just be careful with the wires.
If you unscrew the U shaped plastic piece on the front and the piece of plastic that the antenna goes through on the back, you can CAREFULLY lift the PCB up.
The battery is a 2.4v 70mAh, GP or GE is the brand, forgot what exact brand though.
I want to upgrade mine to a higher mAh, just need to find one.
Hope I helped,
-TheComputerGuy23
11-07-2003, 06:14 PM
thanks but I sont think you can find a battery with higher maH that still gives out 2.4v usnless you do a dual cell
11-07-2003, 08:55 PM
That's all folks
They actually have 2 1.2volt 70ma cells in the shrink wrap, for a total of 2.4volts. They are about 10mm long, standard Zip Zap/ bit batteries are about 15mm long.
That's all folks!
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Size of SE Battery
MicroSpeed |
ZipZaps SE |
2 |
06-23-2004 11:14 AM |
Temp 7.2 battery mod
DRRfanatic425 |
Dynamite Rocket Racer Parts and Hop-Ups |
1 |
08-09-2003 10:47 PM |
Battery Basics 101
Namuna |
Bit Char-G / MicroSizers |
35 |
06-29-2003 09:17 PM |
Battery Size
crusader4x |
ABC DTM X4 |
0 |
12-15-2002 01:15 PM |
battery size
cfactor |
Bit Char-G Parts and Hop-Ups |
2 |
10-21-2002 08:22 PM |
