12-09-2002, 03:51 PM
r.c. dealer .. where are you finding those? online? or in stores? on the street? flea markets?
thanks
12-09-2002, 04:57 PM
they say im slooooow eh?
I think hes a R/C dealer, just look at his name
12-09-2002, 08:29 PM
sportmaxxer2003
dont know if this is on here already
never mind
its the silver clone on ebay
mines the 49 yellow one tho
my contoler is differnt tho
rc hobbies forever
12-10-2002, 04:57 PM
Any pics or links of it???
12-24-2002, 12:51 AM
Bus Driver!
I think we are getting the clone of a clone of a.. Well you know!
Here is another clone but this one has a patent? Also it says it under part 15 but no FCC ID number! HUH?
PS: Its a clone with a wire antenna inside of the car body!
12-24-2002, 12:56 AM
I like, I like. It looks cool with those 6-spoked rims  the wicked lookin controller, and the body looks aight. What kindof motor, etc. is in it? Any pics of the internal antenna you are talking about?
12-24-2002, 01:16 AM
Bus Driver!
Pop a set of bat in the controller. Looks like its going back! When you go in reverse it also turns. Also if you turn it go in reverse. Goes farelly strait. Controller is cheep. Its the car not the controller with this problem.
If you look at the picture of the car can see the wire antenna. It also looks like it has disk breaks visible through the spokes in the back.
12-24-2002, 02:49 AM
Bus Driver!
Tnks xatu!
Due to answering your question I found out with the hyper long wires inside it was shorting the steering and directions!  May your bits never give to problems!  Tnks!
Oh here is a picture of the antenna. Looks like a heavy guage paper clip. Between a normal and a huge! its that squar loop thing. Range... WOW. Est about 15 feet indoors! Through two walls!
The motor is pink? or salmon brown color. Hard to tell been staring at client computer all day!
12-24-2002, 02:56 AM
Bus Driver!
But I save the best to last fellow... what ever we are called!
In this shot you see not a glob of epoxy but a real smt IC the mysterious RX2C! And with it pins expose it may be possible to access the Turbo out pin! All of the remotes I have seen use a normal size TX2 chip with pin seven or is it six exposed its turbo in pin. Now with a receiver chip with exposed pins can back track and create a real 2 speed car!  Santa came early here!
Over the next few days will try to get some distant check done but cant say yes or no right now.
OOPS! Forgot two items. Actions are opposit of what a ZZ does on both L/R and F/R. Also it slugish on start like a IRacers/DigiQ but zooms!
12-24-2002, 11:54 AM
It looks like the color of a 3.8 motor, but I'm not sure. The tires look hard, but that's just me.. .
12-24-2002, 12:06 PM
Retarded Stunt Driver
the color on the motor means nothing
12-24-2002, 01:09 PM
Bus Driver!
Has almost the same zip as a 2.2.
03-13-2003, 08:24 PM
deviant bit char-g pro
Here some new one I have found! Note there rigs!!
My Castrol Supra booster bit owns you!!
03-13-2003, 08:25 PM
03-14-2003, 01:14 AM
Bus Driver!
Wow! How is the drive train? Is it the same as a regular bit? Or special?
