09-03-2002, 01:50 AM
BIT PIMP
proportional throttle mod
This is the ultimate mod, giving you proportional throttle. I have all the parts to do this, but I wanted to know first if anybody has completed this successfully before I cut open the patient. Let me know. Thanks
silla
09-03-2002, 04:25 PM
We'll be doing a review of this set shortly - but haven't installed and tested it yet.
09-04-2002, 12:41 AM
kit? what kit? where can I get one?
Icon
09-04-2002, 04:07 AM
proportional kit?
I think this is the one u r talking about...
www.tapspring.com
09-04-2002, 09:08 AM
theres a bit proportional throttle mod? damn
shoot to kill
09-04-2002, 10:13 AM
It's definitely a cool thing, but it involves a GOOD amount of modification; for one it's a COMPLETE PCB swapout (think LOTS of micro soldering)...ANNNND you're going to need a Digi Propo Controller (the one that comes with the DigiQ kits or the Digi Propo Special for better management of the speed settings).
But think of the possibilites!
- Throw a 3.8 motor in the car and be done with swapping motors! Since you've got throttle control you don't have to swap motors for different tracks anymore
- Throttle control = better DRIFTING control!
- Better battery time too
09-04-2002, 10:32 AM
so basically I just need to buy the digi Q set right? (and obiovusly a soldering kit)
when you mean proportional, do you mean fully proportional or some sort of speed adjustment?
so what about steering? it's the same right?
and whats the general reception range of that IR antenna thing?
I have got to consider this! but i'm afraid i'll screw up and destroy my bit and waste that new digi Q.....
shoot to kill
09-04-2002, 10:59 AM
No, you can buy just the Digi Propo controllers by themselves if you want...The regular Propo can be found for super cheap at HLJ or you can get the better model, called the Digi Propo Special but those will run you $45US+...If you're going to opt for the better remote, you might consider getting a DigiQ to play with too...They're a good amount of fun.
It's FULLY proportional throttle, none of those low/medium/high speed adjustment...The more you pull the trigger, the faster it goes.
IR has a general LOS (line of sight) range of about 20feet...Limitations are that you have to be point the controller in the general direction of the car, and people have reported bad reception in bright light (like sunny day, outside) situations.
It's a definite risk, something to serious think about before trying.
09-05-2002, 04:33 AM
fully proportional? you mean like micro rs4's and mini-z's and stuff? holy damn
can I use another controller? like take the crystal out and put in in another controller? I think the digi-q transmitter looks alittle weird...
and so where do you get the PCV (whatever) board?
thanks!
shoot to kill
09-05-2002, 12:41 PM
BIT PIMP
You can buy it from the link that dumboi07 posted. Check it out
silla
09-05-2002, 01:01 PM
thanks!
Yes, like the RS4 and MiniZ...For throttle ONLY. It's still the jerky steering of a regular Bit.
The mod is to switch from radio to infrared (IR)...Therefore you HAVE to use an IR Controller. Since the PCB board is using IDs 1,2,3 & 4...You're pretty much locked-in to using the Digi Propo controllers.
The PCB board is available from Tapspring now, and I think TinyRC will be getting them in as well.
09-10-2002, 03:26 PM
Micro R/C'er in Da Burgh
I don't solder the magnet wires to the new RX deck! I solder them to very thin stranded insulated wire. I then insulate and glue the soldered connection to the floor of the chassis with plastic balloons goop. The stranded wire is much easier to handle. I use this same cheap goop as threadlock on my mini-X. BAE
Smaller models, more control
09-10-2002, 03:36 PM
BIT PIMP
Hey baleisen, got any pics? On a scale of 1-10, (10 being the hardest) how do you rate this mod in difficulty?
silla
09-10-2002, 09:30 PM
As a thirty year tech(actually longer) I am not qualified to rate this project. I might have burned my first deck. I never buy 1 . Always at least 2. My method brings down a difficulty of a 7.0 down to a 3.0. INHO. Next month I will buy another delux digi controller and modify another Q to go with it. If it would interest people I'd be willing to document the operation and donate it to the TinyRC archives. Do to the extra work involved, I;d like feedback as to the interest. Thank you. BAE
09-11-2002, 04:33 AM
Why spend money for a kit, risk a OEM or a Tomy, when you can get the full working BitChar-Q (the modified version with IR) for 15 bucks remote included ?
TinyRC has it: http://www.tinyrc.com/shop/product.php?pid=133
Gif4All in London Airport has it (all the 4 ID)
ToyEast was having it time ago, maybe they will come back !
P.S: As far I can understand from the BitChar-Q, that I belive use same HW then the Kit, the throttle has around 8 step (4FW+4RW), but the signal to the engine isn't progressing continous power with different voltage, but is a square wave with the up time increasing, so with full throttle the square wave is a continuous signale, with minimum throttle the engine recevie some voltage spike.
So the car is far more noisy while half power then in full power !
