Old 10-29-2002, 03:29 PM
goodorange goodorange is offline
turning radius
I have been working on my Bit, and find that it has a much larger turning radius on left hand turns, compared to right turns. I have switched every part i can think of in the front assembly to try and fix it, but nothing really works. What could be the cause of the uneveness in left/right turns?
Old 10-29-2002, 07:24 PM
bherrin's Avatar
bherrin bherrin is offline
I would say that they wheels are not turning as much to the left. If you look at it while it in your hand and turn it one way and then the other are they turning the same amount. Something might be binding up or loose.
Old 10-29-2002, 08:31 PM
i've changed the steering magnets, and the entire assembly's both right and left in my car, and the turns only seem to get bigger! I can't get it to turn small
Could it possible have to do with how the steering coils are wound on each side? Like if one has less wire, it might not have as much strength in that direction?
Old 10-29-2002, 08:41 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
i have a bit of problem with that, but i think they're all like that. It seemed like the radius was getting larger everytime i would run. I fixed that problem by running the car on a damp napkin to clean the tires. This braught me back to normal turning. Yes the right is still better than the left, but not by much, i'd say about an inch or so.
Old 10-29-2002, 10:17 PM
ok, thanks!
i'll try that trick tonight if i have some time...glad to know i'm not the only one
Old 10-29-2002, 11:20 PM
cowfish_29's Avatar
yellow fish forever!
some cars are just like that, but not all of them. Running them on a smooth surface with hard (bit racer) fronts and soft (bit char-g) back tires and a fast motor will hide the difference pretty well, along with a soft stablizer or the QFM springs.
Old 10-30-2002, 02:16 PM
shane45-1911 shane45-1911 is offline
Big kid
Assuming your magnet is centered, and there is no wheel binding - I found by GENTLY and SLIGHTLY bending the steering spring ends in one direction or another (either away or towards the center pin) it may help. Not enough that they lose contact with the center pin, but just enough that there is not quite so much tension on it.
I have found that this will either increase or decrease the radius in one direction or another.
Old 10-30-2002, 03:00 PM
SPEED's Avatar
SPEED IS GOOD
I agree with that last post!! It all depends on the steering spring orientation. If the spring is bent to one side that can cause bad alignment, it has nothing to deal with the other steering components (except when the magnet is out of plce).
Old 10-30-2002, 03:06 PM
323iT's Avatar
323iT 323iT is offline
you could always try different tires on the left and right side. hope that would help
Old 11-01-2002, 12:03 PM
Diego's Avatar
Diego Diego is offline
You should check if the tires spin equally at both sides. Happened to me and found that some hair stuck in the front wheels was causing the problem.
Diego
Old 11-01-2002, 08:28 PM
Bunta Bunta is offline
Hi everyone,,
I find that tires affect the steering alot! Sometimes there is a difference in the tires from left to right,, (maybe the sun was able to cook only one tire or side?) anyhow, when the tires were replaced the problem went away.
Maybe you have a tire more dirty than the other?
-Bunta out
Custom Mods R us
Old 11-03-2002, 01:01 PM
tinyrc's Avatar
tinyrc tinyrc is offline
goodorange, another thing that can happen is that one of the wheels on the rear axle can become loose. This happened on one of my cars, and the result was that steering in one direction was extra tight, and the other direction was awful. Pull your rear axle off and see if one of the wheels moves freely. They should both be locked.
Old 11-07-2002, 11:02 PM
mikey-flies
I've tried everything listed here and I can't find the problem yet with one of my little cars. Right turns are about 2x the radius of left hand turns. I adjusted the spring so that it would hardly even return from the right; no appreciable difference in turning radius. Carefully checked the copper wires (one may have been in contact previously with a bit of bare wire leading to the motor); no appreciable difference. I made sure the magnet was centered and clean, glued in place and that both coils were clean and glued in place; no difference. I've checked the front tires and both spin evenly, checked the back and both are solid on the axel. I've adjusted the suspension from rigid rigid rigid to loosey goosey and nada. I did notice some bright marks on the positive coil leads (possible chips in the coating?) but these are evident in both left and right about the same so... :/ I suppose I could get some enamel and paint the wires to help insulate or something but is that even a reasonable thing to try? Are the coils hollow? Would trying to insert a piece of piano wire into the middle increase the flux? Any suggestions
Old 11-07-2002, 11:08 PM
cowfish_29's Avatar
jeez..i think ya stumped us..wow...ive got no idea!
Old 11-08-2002, 08:39 AM
Big kid
I'll say it again. It is the STEER SPRING.
You need to bend one of the leads slightly away from the center pin. Not enough that you lose contact with the pin, just relieve some of the tension. You will find your car turns sharper now. If it is wider, you have "de-tensioned" the wrong lead. Bend the other lead out a bit (again, not to the point where it loses contact with the center pin when reassembled!)
Turning Radius? hschnark ZipZaps SE 3 04-19-2006 07:05 PM
turning radius rob3662 SuperSlicks 0 12-08-2004 05:54 PM
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 02:32 AM
Uber Help Needed w/ Turning Radius. ZipRC ZipZaps SE 5 10-01-2003 08:26 PM
Is there a way i can shorten my turning radius on my Bullet? SPEED Bit Char-G / MicroSizers 0 08-23-2002 11:57 PM
