01-31-2004, 07:48 PM
D1 Grand Prix
Re: home made peak charger...
Originally posted by killer
modified cellphone charger... red when charging.. and turns green when full charge!
how did u make that conversion with the red light thing?
hi, i am here
02-08-2004, 07:54 AM
Proud to be Pinoy :)
:ö: that is a built-in led light on the charger  -æ
hehehe
02-08-2004, 07:11 PM
B-rad G from the boo
Thanks for the diagram Killer, Any chance you have any build-up pictures??? It would really help, I mostly just need to see the steering knuckles and how you made the u joints for all of it. Also, what kind of stock are you using for them, it looks like allen wrenches almost,lol, and lastly: how do you drill so SMALL!?
Thanks,
Brad
02-09-2004, 09:19 AM
i use the u-joint design on the mikromodell site but instead of using a brass tubes i used the Tamiya Monster truck steel hex shaft, as for the tiny holes i used a 0.8mm drill bit installed in a mini-drill press.
hehehe
02-09-2004, 09:22 AM
here's the u-joint diagram from the mikromodell site.
hehehe
02-09-2004, 09:24 AM
and here's a close-up pic of the front axle..
hehehe
02-09-2004, 09:26 AM
here is the front axle on top of my hand..
hehehe
02-09-2004, 09:40 AM
here's a picture of the u-joint.
hehehe
02-10-2004, 08:11 PM
WOW!
Thanks a lot Killer! That will help tremendously, since I'm not equipped for that kind of small scalle stuff I'll just have to make 'em out of some super beefy round stock I have lying around, Thanks again Killer!
02-15-2004, 03:25 AM
your account is full!
i recieved your e-mail, i sent you the answer but your account was full.. so i guess i'll post it here
the thick rod will not slip out because the thin rod prevent it, remember that the thin rod pass thru the thick rod, now if your talking about the slack that's the reason why we have to put the square thing in the middle.
hehehe
02-20-2004, 06:10 AM
ah of course!
thanks
02-20-2004, 11:20 PM
killer, i really want to build a rock crawler like yours, but i dont know much about this stuff.
are you running it on 2 seperate motors?
if not how is the drive train set up?
Can you show me some better explanations of ythe front axle/rear axle?
thanks for everything
02-21-2004, 04:58 PM
ans: on my 1/35 txt-1 i used a two 130 type motor setup just like it's 1/10 counterpart..,but on my 1/35 rock buggy i used 1pc N20 type motor
ans: as for the 1/35 rock buggy gear train click here
i've also attached a drawing of how i placed all the gears on my 1/35 trucks..
ans:
i've posted some pics of the front axle on this thread, pleas do browse this thread a bit..
it works like the real front and rear axle of any 4x4 truck, but the difference is that all of my axles lack differentials or if we compare it on a 1:1 version it's called "spool ".
i hope this helps
hehehe
02-21-2004, 05:04 PM
this is my twin motor set-up..
hehehe
02-21-2004, 05:36 PM
hey killer have you ever thought of using an xmod diff. on one of your trucks. im not sure if a diff makes that much of a difference with a truck this small but its just a thought.
