10-08-2003, 08:56 PM
Confirmed: Lost In Fog
Anyone have a spare motor/ gearbox assymbaly i could buy?
Anyone have a spare motor/ gearbox assymbaly i could buy? this and the axles are the only things i need.....i have the radio equipment and micro servo aswell as quick access to a 135mAh li-poly cell.........thanks! please PM me if you can help out....(do PM's work on this site?)......
thanks again!
-Andres
10-09-2003, 07:02 AM
im a micro daddy...
boris most people scratch build their gearboxes and are made to fit the chassis that its going on(usually being a part of the chassis anyways) so its not really going to be easy to make a gearbox without knowing the chassis its going on.
i see it as having 2 options:
1. buy a ready assembled motor/gearbox combo from germany
2. buy the gears/motor and make your own from germany
why not get the parts from germany like i do,i dont know how much shipping is to usa from germany but peter is a nice bloke and accepts paypal also
dave
10-14-2003, 07:07 PM
Proud to be Pinoy :)
:ö: a 9gram or smaller servo! has most of the gear parts and the right size motor needed to run a 1/87 truck, minus the worm gear
and the servo electronic board can be modified to micro esc.
-æ
hehehe
10-14-2003, 08:09 PM
hmmm...ill have to see how big my other servo is...hmmmm.....ive got two because it is a flight set i got for i micro flight plane i did not finish.............ill toss the worm gear and then what? what mods bo i do on the board its self?
thanks for your help!
-Andres
10-14-2003, 10:51 PM
:ö: just replace the potentiometer with resistors... like
this..
hehehe
10-16-2003, 04:23 PM
B-rad G from the boo
is the resistor change fully neccasssary killer?  I am too lazy to want to do it.
10-16-2003, 04:38 PM
i tryed pluging the servo into the recever and moving the throtle on the controller and only got a jerking motion.........oh, and as im using aircraft electronics i have no reverse so when im in a trial, its all or nothing, lol!
-Andres
10-16-2003, 04:56 PM
:ö: it's not that necessary  , but you could save a lot of space if you do this mod, 2 resistor are smaller in size than the smallest 5k ohm potentimeter you can find, this will also eliminates the need for you to turn or adjust the potentiometer "on the truck" everytime you turn it "on"  .
-æ
hehehe
10-16-2003, 05:06 PM
:ö:maybe your battery is already used up, use freshly charged batteries on your TX and your truck, hope this eliminates the twitching  , i wonder if aircraft esc's have reverse!  , you should try using a modified servo board.. it has reverse!
-æ
hehehe
10-16-2003, 05:15 PM
oooooo! im exited, i just got order conformation on the roco trucks! 4-5+ days till they get here! (then i really get to trial!)
im recharching my controller and receaver so i can try this again.......im not sure they were charged to the peak last time.....
-Andres
btw, killer, do you have AIM? if so, whats your sn?
-Andres
10-16-2003, 06:14 PM
:ö: sorry, don't have one  .... but you could e-mai me at: killer_d76@digitelone.com -æ
hehehe
10-16-2003, 07:41 PM
The Verdict....:
the servo pluged into the rx directly makes it act like a throtle servo for a nitro/ gas powred plane....lol......i guess i will have to mod the board!.......hear goes nothing! (ill order an extra gws servo just incase.......gws is less expensive than hitec....)
-Andres
10-17-2003, 12:54 AM
"DON'T TOUCH ANYTHING!!!!!"
:ö: it acts like a throttle servo for a nitro powered car?..., ei, do you have a spare TX aside from the one you are using?, i believe you are using a single stick 2channel FM tx for airplane... try another type of tx, that should work!, unless you want to have a drag racing truck!
-æ
hehehe
10-17-2003, 09:32 AM
its a 3chanel, the stick is elevator/rudder (or flaperons) and there is the throtle control on the back side........its a clever design.........ill post a pic....
-Andres
