Old 09-23-2003, 01:01 PM
ibbored ibbored is offline
Send a message via AIM to ibbored
How do you make old zz battery's fit into the se?
hey guys,
I just got my zip at radio shack yesterday and I also got my perfection 4.2 and 4.2 pro, and 200 MiAh or whatever battery too. Not knowing that it didnt fit into the new se's. So is there any easy way to get the old, smaller batteries to fit into the new se's? I doubt that bending the contacts out would be enough so would like some solder on the end work? Or would that harm the battery? Thanks for your advice in advance.
Old 09-23-2003, 07:40 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
You need two old batteries to match the new higher voltage.
Old 09-23-2003, 09:48 PM
itsalllies's Avatar
itsalllies itsalllies is offline
bite my shiny pimpmobile
you don't
Old 09-23-2003, 09:57 PM
how many times to charge 200 MiAh battery?
just wondering becuase i have one in my new se. I have been doing it 5 times is that to small?
Old 09-23-2003, 09:59 PM
whoops sry i meant to make that a thread, but u guys would probably know anyways. I bent out the contacts and got it to fit, so now i need to know how many times to charge it.
Old 09-24-2003, 12:31 AM
bdebde's Avatar
bdebde bdebde is offline
That's all folks
A single battery will likely not work. It is only 1.2 volts, the SE needs 2.4 volts.
That's all folks!
Old 09-24-2003, 10:28 AM
JackD JackD is offline
ITCOB
Is a dual cell possible with a ZZ SE ??? I'm looking for a little more speed/power out of the SE I bought yesterday.
Old 09-24-2003, 12:51 PM
dr1zz's Avatar
dr1zz dr1zz is offline
phear meh..............
i threw in a 1.2v 210 mah battery and it worked fine.......got the batt frome extrememicros
speed is pretty equal to the stock battery......
i also took out the charging base off one of my controllers....
hooked it up to a digital peak charger.......and charged.....
then slapped it back onto a controller to sync the channel.....
works great.......
Old 09-24-2003, 01:33 PM
TypeZer0's Avatar
TypeZer0 TypeZer0 is offline
0reZepyT
works great.......
are you referring to an SE or the original zips? cuz i kno that the SE's cell is really two button sells shrinkwrapped together in series to produce the 2.4 volts and replacing it wiht a single 1.2 volt cell would make it either slower or not work at all due to the pcb's voltage requirements to make it work
anywayz, i think if you have the small cells for the Layman's mod, you should be able to fit 3 or 4 in teh same space as the stock dual cell in the SE
Friends (Joey's Bag)
Rachel: Exactly! Unisex!
Old 09-24-2003, 08:25 PM
bdebde's Avatar
That's all folks
I believe that it is a SE, he had to sync the channels after peak charge. I guess I will have to hack a controller for a charging base now. I love the performance and run time that a peak charged bat gives.
That's all folks!
How do I make these rims fit on an XMODS? geofroley XMODS Mods and Projects 1 12-04-2003 06:45 PM
How do i raise the RSX body to fit extra AAA? georgc XMODS Mods and Projects 1 11-19-2003 05:03 PM
make custom plates. dragon4450 XMODS Mods and Projects 9 11-18-2003 04:13 PM
would these fit on a civic? Spooney XMODS Mods and Projects 5 11-17-2003 12:54 AM
who can make custom bodys?? GoOsEmAn Bit Char-G Gallery 28 03-15-2003 04:28 AM
