Old 12-15-2002, 02:38 PM
TallgeeseIIII's Avatar
TallgeeseIIII TallgeeseIIII is offline
Send a message via AIM to TallgeeseIIII
My Hovercraft Mod Thesis
For some time now, people have been trying to create a Bit Char-G hovercraft, to my knowledge all have failed. But my new theories may solve some of the problems they have been having. In this document I will discuss my plans for a completely possible Bit Char-G hovercraft, and furthermore, future plans for a Bit Char-G Helicopter.
The first problem to be encountered in this endeavor is a suitable motor for the bottom fan. It needs to be strong enough to lift at least 8 ounces, most likely more. The bottom fan does not lift the hovercraft it self though, the air is actually forced out the sides through a fan (Figure-1). An air bag catches this air and the air is then forced out a grated plate in the bottom. Instead of having the air forced out in every direction, the bag is initially forcing the air straight down. Not only that, it focuses the air to a smaller area creating more lift.
When my brother's and my CD Players broke, we were going to get them fixed, but instead invested in MP3 Players. I looked inside them and discovered I could fix them myself with my somewhat limited but still capable knowledge of electronics, but, I did not have the right parts, so, I left them open for later when I expected to get the parts, bad idea. I came back to them eventually. I had them in a box of electronics pieces in my room. That was a bad idea, they were destroyed. One had a scratched laser, and the other had a broken LCD screen. Fixing them was out of the question now so I salvaged the 4 motors. I took the two motors that spin the CD (Figure-2) and the two that move the laser up and down the track (Figure-3).
Well, the motors were cool on their own but I had to test them, the 2 that spin CD's are apparently grossly underpowered, their capabilities were awesome! I attached a AA Battery to each and discovered that that was about the power they were getting to spin the CD. Then I tried a 9v battery, they spun up immediately, like 0 to 60 in under a second! I then tried them with a CD on them, well, that was 0 to 60 in about 1.5 seconds, not only that, it was giving air off like a fan... IT'S A CD! There's nothing on a CD that could possibly give off air, it was pure speed! well, with a 9 volt battery, that could lift the Bit Car-G with the right rotor blade like a helicopter, we'll get into that later... >
Anyway, I ran it for about 5 minutes straight and it never over heated like I'd expected it to do, by the way, I cut my thumb on the CD when it was moving (Figure-4). So, obviously 9v is too much power for a hovercraft, but about 6 is perfect, and with some of the battery mods out there, that can be achieved! To recap, the CD spinning motor will make an excellent bottom fan for the hovercraft in theory.
I have heard of people talking about having their hovercraft have one motor and be steered by rudders, that's all fine and dandy if you want a fan boat but this is a hovercraft. The way to steer this is by twin micro motors (Figure-3), I'll explain. If you have two motors in the rear, then pressing forward should turn both on, pressing reverse should turn both the opposite direction, and pressing to the left should turn the right motor off, and pressing right should turn the left motor off. That's where the second set of motors I retrieved comes in. These two motors are too heavy, but, 3.8 micro motors are not! You ask anyone who has a 3.8 in their car, "What are the three biggest problems with it?" and they'll tell you acceleration, handling and torque. Well, if you're not spinning wheels on the ground, friction is dramatically reduced, so torque and acceleration are somewhat solved, and turning isn't being done with magnets anymore so there's nothing to hold you from turning because you're just shutting one of the motors off.
So, if you get a good material for the air bag, mount several micro batteries to a lightweight hull above the bag, (make sure you leave space for air to go in above and below the hovercraft to the bottom fan), mount the CD spinning motor in the hull with a fan, then mount 2 micro motors to the rear, rewire the steering so instead of powering small electromagnets, they power rear fans, rewire forward and reverse to those fans as well, then mount a micro switch to your hull that when turned on activates your bottom fan, and there it is, a hovercraft, the only thing you have left to do is get your weight right, try not to add weight, instead shave off extra plastic, use shorter thinner wires, and no heavy metal materials for the hull or bag. try to find a lightweight CD spinning motor, one of my CD spinning motors is lighter and has less torque but better acceleration, and the other is heavier and has more torque and speed but less acceleration, so try new things, if you want style too, try to keep it free to add a body as well, and the antenna must by clear of the fans.
Some of you may have a few questions like these:
Q: "How old are you and why do you think you're so smart!?"
A: "I'm 16; I took apart an RC Hovercraft to learn more about its physics."
Q: "If you know all that, why don't you just build one now...?"
A: "Essentially I could but I don't have the micro RC parts, as soon as I get those I will."
Q: "You make this sound easier than it is, how do you explain that?"
A: "This is in no way easy, remember, many people have failed at this already, if there is anyone who has succeeded, I'd like to see it! "
Q: "Why is this so long!?"
A: "If it was easy it wouldn't need to be this long, so that emphasizes the question above now doesn't it."
If anyone else has questions, comments or concerns just post below.
My Dream Car (No, I don't have it yet):
Shiny Green Toyota Supra
Old 12-15-2002, 02:39 PM
Figure-1
Old 12-15-2002, 02:40 PM
Figure-2
Figure-3
Old 12-15-2002, 02:41 PM
Figure-4
Old 12-15-2002, 05:02 PM
am i gonna get any feedback on this or is everyone too lazy to read it all, it's really interesting, i guarentee it is!
Old 12-15-2002, 07:09 PM
slugbugg slugbugg is offline
I KNOW NOTHING!!!
Well it sounds cool
But I wonder, just how big is this thing going to be?
It could be fun to have a micro bit hovercraft but the weight will be a problem, it would be very light if the main body/chassis were made out of lexan and vacume formed over a cool shape.
I wonder if mylar could be heated and shaped to form a skirt for the bottom.
can hardly wait to see the pictures of it.
Old 12-15-2002, 07:39 PM
dustn's Avatar
dustn dustn is offline
Poor Student
Send a message via AIM to dustn Send a message via Yahoo to dustn
Mylar is the exact material i was thinking for a skirt. Mine will be made of 1/32 balsa and/or the foam stuff from meat trays. The plan is to have a single motor, possibly geared to a small home made fan, with 33% (that is typical for full size craft) ducted under the hull. Steering will be by multiple rudders behind the fan. More details and drawings to come after i get home after exams. In the mean time, here is a pic of my own-design larger craft. A note... The thrust is a Graupner 550 spinning a 8-4 prop, the lift is a Graupner 400 spinning a 6-3 prop. The 400 could be run at half throttle and still lift the craft, and that was with 2 speed controls and 2 6-cell sub-C battery packs. The skirt is just some 1/2" foam taped around the sides because i hadnt made a flexible nylon skirt yet. It worked fine on flat stuff... Anyway, more later.
Fight Crime <--> Shoot Back
Old 12-15-2002, 07:46 PM
dustn's Avatar
Poor Student
Here is it flying... It was in preliminary stages, so excuse the stuff hanging off.
Old 12-15-2002, 08:02 PM
dustn's Avatar
Poor Student
I forgot... The planned size of the micro-hover is 4"x2.5"
Old 12-16-2002, 04:47 PM
Sniper596's Avatar
Sniper596 Sniper596 is offline
I'm 1337 r/c'er :)
Originally posted by TallgeeseIIII
Figure-4
LMAO!!!!
Old 12-16-2002, 08:22 PM
don't laugh at me... it hurt too... like a rug burn at first...
Old 12-16-2002, 08:27 PM
oh yeah, and the planned size is length 3 x width 3, the height isn't for sure yet.
Old 12-17-2002, 12:22 AM
Snow Snow is offline
DDR PIMP
Keep us posted! I wanna see how it works.
Thunder Charger
Old 12-17-2002, 03:54 PM
thanks, i will, btw, i have a bunch of friends with broken cd players and other stuff so they're all giving them to me for extra parts!
AWD with Resistor Mod for steering cool_cars XMODS Mods and Projects 20 12-04-2004 03:10 AM
Best Mod Contest (UNOFFICIAL) midget_man1387 Bit Char-G Mods and Projects 56 03-17-2003 10:38 PM
