Old 09-26-2002, 08:08 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
ill be the first
well i got a zip zap and i have to syait pretty good its not as fast i would like it but hey i like the whole idea of the mustangs and cruisers and the fast and the furious kit is great (thats wath i bought) i didnt like the movie but i like the detail on the car zip zaps are the best clone ive found so far
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 09-26-2002, 08:46 PM
Def Def is offline
i got the zipzaps too. so far so good but like you said, it's not as powerful.
Old 09-26-2002, 09:03 PM
Chris's Avatar
Chris Chris is offline
Send a message via AIM to Chris
its not as powerful probably because it is larger and heavier than the bits
when you've tried everything and you still lose, there is only one answer, NOS
Old 09-26-2002, 09:33 PM
kwikbb's Avatar
kwikbb kwikbb is offline
smoove operator
I agree about the lack of power and I think that the intrest of the "NOS" motor, which is only 23,000+ rpm, will quickly be outlived. And forget about putting a bit motor in, there's just not enough tourqe to push the heavier zz. I tried my 2.6 in there and it ran slower than the stock 1.6 of the zz
Hopefully someone will disect the zz motor and make some kick@ss aftermarket 4.0's or 5.0's
Old 09-26-2002, 09:39 PM
Chris's Avatar
ya. that would be cool. with a 5.0 motor, those zip zaps would kick a$$! anyway, I wonder why the bit motor didn't work in it. are the zip zap motors any bigger in size than bit char motors? and would anyone suggest buying a zip zap cuz I was in radio shack today and was contemplatin buying one, but I decided to wait and see what other people think of them. so, IS IT WORTH THE $20??
Old 09-26-2002, 09:46 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
If you have a bit char-g right now you should just buy the tune up set for the ZZ's. Most of the parts on the ZZ tune up set are compatible with the Bits. I have a question.......has anyone put the "NOS" motor in the bit char-g yet???
Old 09-26-2002, 09:48 PM
Chris's Avatar
so what is and what isn't compatible with the bit in the ZZ tune up kit? do the bodies fit on? do the motors fit in the bit? do the tires fit on a bit? stabilizer bars? axles?
Old 09-26-2002, 10:01 PM
kwikbb's Avatar
smoove operator
No the bodies don't fit, zz's are 1/64th scale and bits are 1/72th scale.
Motors can fit in the bit with a little finegling, but as i said before vice versa does'nt seem to work to well.
Yes the stabilizers are cross compatable.
The axels on the zz's are longer than the bit's. I tried to put the bit axels on the zz but no luck too short it kept locking up, so I took the rims off the zz axel and replaced them some spare bit rims. For the front I did the same, so i've got bit rims all around. (personally I think it looks better)
Old 09-26-2002, 10:06 PM
Chris's Avatar
hmmm. I guess I should just get a zip zap then since only a few things are compatible in the tuner kit. why buy it if you are only going to use 3 or 4 parts from it. oh yeah, and I know I am going to sound like a cpmplete newbie, but wat is the point of having hard,soft, and medium stabilizer bars. what difference would it make performance-wise (I'm just Chock-full-O questions tonight!!)
Old 09-26-2002, 10:18 PM
Def Def is offline
I got around to replacing the wire antennae and it improved the reception a couple of feet. I also took apart the remote control but it doesn't appear to have the exact same layout as the others. If anyone has any other modification to improve antennae reception/performance, please let us all know.
BTW, for those who already bought the zz with the fast and furious kit, what combinations do you find to be the best? I'm using the NOS motor w/ the green gear and 3rd stabilizer. Everything appears okay and it's faster than the stock but of course the car seems to drift at high speed.
Old 09-26-2002, 10:22 PM
kwikbb's Avatar
smoove operator
what is the point of having hard,soft, and medium stabilizer bars. what difference would it make performance-wise (I'm just Chock-full-O questions tonight!!)
Welp my experience has been finding the right combination based around what motor you're using.
For example my bB has:
2.6 motor
soft stabalizer (better in the corners, less tension on the body)
medium tires in the front
soft in the rear
lowered the body on the chassis in the front
My Supra is running:
2.2 motor
custom modified stock stabilizer (I shaved it down a bit so the car would sit lower but has a little more tension, I've found that the Supra flips over more easily) again a better combo for cornering.
Soft tires in the front and medium in the rear
So far this is the best combo I've found for my driving style. Full throttle
Old 09-27-2002, 05:55 AM
Bus Driver!
The basic concept of half charger/ half transmitter is the same but exactly how it does it is different. Some thing like how it modulates and connect the buffer-final to the antenna are different. The output filter is different. Other items like generation of the tones values could be different due to changes in a resistor value on the TX2 IC.
I would strongly recommend dont monkey with the output! Dont start clipping parts since all are needed. The designed was set up to meet FCC reg on output power level and spur's. Esp the way it modulates the RF with the signals from the TX2 IC. Its different than a Bit. The odds are you would decrease the range or muck up how it modulates the signal so in effect your transmitter is dead if you start clipping parts.
Old 10-09-2002, 09:52 PM
prooney prooney is offline
Question Battery life?
jhandel,
How long do the batteries last before you have to swap them?
Old 10-10-2002, 08:24 AM
lowerdfool's Avatar
lowerdfool lowerdfool is offline
Microrcfool
Send a message via AIM to lowerdfool Send a message via Yahoo to lowerdfool
yes please post a schematic for us i'd like to see how that's done.
"What's a low fool?" lol
Old 10-10-2002, 08:26 AM
Bus Driver!
If you dont mind. If you have a schematic of the "boot" battery add on, they may be a way to use a diode to block the charge voltage but let it work when not charging.
Have done strange switches with diodes over the year.
