Old 03-20-2003, 09:06 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
Detailed dimensions...
There's been a little debate and just plain WRONG information given about what the dimensions of the Bits are and whether certain things will fit (like motors and batteries).
Well, I took my Digital Caliper out (accurate to +/- 0.02mm) and took some measurements...Once and for all, we'll KNOW the real deal.
The Bit Chassis:
- Outside measurement of the section that holds the battery: 18.3mm
- Stock NiCad battery: 10.3mm diameter x 15.4mm tall
The ZipZaps Chassis:
- Outside measurement of the section that holds the battery: 18.6mm
- Stock NiMH battery: 10.3mm diameter x 15.6mm tall
* Those outside measurements includes the thickness of the chassis AND the metal tabs that the batteries touch...Which makes up about 2mm worth. So you MIGHT be able to push up to a 16.5mm tall battery in the ZipZap and a little smaller for the Bit.
With only 0.3mm more width, the ZipZap DOESN'T offer that much more width vs. the Bit.
Hopefully that clears some things up.
Old 03-20-2003, 09:22 PM
d00kie's Avatar
d00kie d00kie is offline
It's super useless!
Despite its superiority in length, the ZZ doesn't offer much of a wider space for batteries than a BCG eh.
BTW you accidentally added a '/' to [b].
Old 03-21-2003, 02:01 AM
sessiz10's Avatar
sessiz10 sessiz10 is offline
Told ya.
Thank you. That is extremely helpfull.
____________________
Meh.
HELP! Need dimensions on 180 motors binaryterror Mini-X 3 02-06-2003 10:54 AM
Ideal track dimensions DarthRacer Tracks 5 11-30-2002 01:27 AM
need dimensions of the ChoroQ penny racers MTL Miscellaneous Discussion 2 11-02-2002 02:09 AM
