Go Back   TinyRC.com > 1/64 and Smaller > Bit Char-G, MicroSizers, Z-Cars, Clones > Atomic Z-Cars
Old 03-08-2003, 01:14 AM
trinitron2k2
Controller Mod
I have my Z double celled and the controller is not too great for charging....is there a way to mod the controller so I can plug it into the wall (AC...) that would ge great. Thx
Old 03-10-2003, 05:36 PM
MST3KPIMP MST3KPIMP is offline
you can hook up a power jack on the controller to accept an adaptor. Kinda tricky as the controller is so tightly packed. What i've done is use a 4.5v adaptor and just use the raw wires instead of a connector. I slip them into the spring terminals on the top and bottom. I then squeeze in 2 aaa batts to hold them in.. You may find a neater way to do it.
Old 03-10-2003, 06:11 PM
Heat's Avatar
Heat Heat is offline
Zhuge Liang - My Idol
go buy a battery holder from radioshack. it like holds 4 AA batteries and has 2 wires sticking out, blue and red. just take the charging platform from your controller and solder the two wires onto it and you have yourself a charger. but since it is just 2 wires with a box that holds batteries, it doesnt have a timer so you hafta take care in not burning out your car.
Old 03-10-2003, 07:34 PM
BillyP
The LEDs in the controller don't work right with my 4.5v AC adapter. The charge light and the air light always turn on together. But it's cool because I don't need to buy batteries anymore.
controller mod natedogg4674 ZipZaps 2 01-10-2003 12:27 PM
controller mod natedogg4674 Bit Char-G / MicroSizers 4 10-29-2002 02:49 AM
controller mod & solution for poor range natedogg4674 ZipZaps 4 10-13-2002 09:40 PM
cheap zz controller joystick mod lnx_author ZipZaps 12 10-13-2002 12:21 PM
