Old 03-03-2003, 04:31 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
pullback wheels
are great. my car runs everything over. it handles high speed turns 10x better. if you have a dual battery car you need these wheels.
Old 03-03-2003, 04:56 PM
Superimport2nr Superimport2nr is offline
MASTER PAINTER
Send a message via AIM to Superimport2nr
i need help converting the back axles to work for the bit,
help would be appreciated
Old 03-03-2003, 05:24 PM
hogjowlz's Avatar
it was fairly easy.
i took a drift axle that i had and ripped off the drift wheels. i broke the axle part so i used a clone axle. cut it to the right length, the pullback wheels are thicker on the drive side wheel i had to cut out the center axle holder part a little bit so the gear sits flush against the wheel.
then i bust out my handy dandy
"jbweld" do a search on that word if you are not familiar
mix it up real good and put a little bit between the drive wheel and a little bit on the gear. be extra careful not to get any on the teeth. and then i put more jbweld on the non drive side. play with it all for a few mins and try to center so everything is straight.
after an hour or two i put it on the bit and started running it upside down so the weels move with no load to make sure everything is true and adjust until it is.
jbweld takes about 6 hours to harden completly.
i also painted the rim face with a silver paint marker. it looks swell.
**note**
the drive side wheel sticks out slightly further than the non drive side. i could have chopped at the wheel to make it look mor symetric but i dont care and it drives just fine
Old 03-03-2003, 05:42 PM
MASTER PAINTER
what about getting the wheels off the axle?
Old 03-03-2003, 05:46 PM
hogjowlz's Avatar
off the pullback or the bit?
i twisted one side off. then held the axle with needle nose and twisted the other side.
lego wheels on like stock wheels sawhit4 XMODS Parts and Hop-Ups 4 02-18-2004 07:29 PM
stuff caught in wheels jbach39 ZipZaps SE 10 10-26-2003 06:38 PM
fs. 27mhz booster chassis, Pullback wheels on knckles +axle, +bodies!!!! eman1 For Sale/Trade 7 09-11-2003 08:39 PM
RX-7 starring The Pullback Mod CaboWabo Bit Char-G Gallery 8 04-08-2003 04:16 PM
WoW!Pullback wheels in a bit! MythosGR Bit Char-G Mods and Projects 15 02-06-2003 03:42 PM
