03-02-2003, 12:29 PM
Redneck Drifter
clone problems
i need a little help here, my "micromites" clone has had some problems. when the car gets more than a few inches away it doesn't work. i don't think it the car because it works fine with other controllers. i have had this car for a while and it just started doing this lately. thanks for your help
03-02-2003, 12:33 PM
Corolla Power!
Well it's probably just your controller that's acting up. Try doing some mods on it to increase range. Go to www.questformadness.com and go through their mods section, it's actually quite extensive
03-02-2003, 12:56 PM
Redneck Drifter
but, i don't get why it's done this all of a sudden, like i said it has worked fine for a long time
03-02-2003, 02:44 PM
Rice Me
hmm try checking antenna connections.... if the car works fine with other controllers, it might be the controller antenna not contacting properly..
03-02-2003, 02:57 PM
Redneck Drifter
i'm fixin to open it up and have a look
03-02-2003, 07:00 PM
Redneck Drifter
it looks fine nothin lose or fried, the antenna is making good connection with the metal thing i don't know what wrong
help me
03-02-2003, 07:29 PM
BitPimp Enforcer
ViperKid
I'm assuming you have fresh batteries in your tx????
Something in your tx may have gone bad. If a transistor / resistor has failed you probably won't be able to physically look at it and tell unless it actually burned. If your car works okay with another controller, use that one in the meantime while you work out the problem with your tx. What frequency?
DarkTari
DarkTari
If It Don't Fly....."MODIFY"!
03-02-2003, 08:16 PM
Redneck Drifter
batts are brand new, and the freq is 27. it's one of those bensn round controllers.
the controller i am using for it now is the one with my moto gp, it looks the same but the charger is different. it stinks because i have to charge with one controller and drive with another
are those Tomy multiband controllers still around? thanks
03-03-2003, 02:59 PM
BitPimp Enforcer
YeP !
Check TE.
DarkTari
DarkTari
