Old 02-20-2003, 06:27 PM
MicRoMaN's Avatar
MicRoMaN MicRoMaN is offline
Microman to the rescue!!!
ZZ Rims..
I was thinking of picking up a pack of ZZ rims and tires. What modding is needed to fit these on a MS? I hope you guys can help, thanks.
-----My Mini R/C Site-----
Old 02-20-2003, 09:34 PM
Zephyranthes's Avatar
Blitzer Sonic
Nothing. Just replace the steering knuckles. Now drilling, hammering, or soldering required.
Old 02-21-2003, 05:19 AM
strider_mt2k
Agreed.
I've even used the rears to make a ZZ wheelset.
Old 02-21-2003, 11:27 AM
MicRoMaN's Avatar
Do u think anyone could give me some instructions on how to do this? Thanks.
Old 02-21-2003, 11:50 AM
Gent Gent is offline
You have 2 options:
1. Buy a Zip zap and then take off the body of the car and remove the front steering knuckes and front wheels, and swap the with the steering knuckes and front wheels on your Bit. You can remove the knuckles by either lifting them up and pulling them out, or by unscrewing the cover on the front of the car and then taking them out.
2. Buy the ZipZap gear kit, and the ZipZap Rim and Tire kit. Take two of the rear rims from this kit and separate the rims from the gear and the axle. Now take the 2 rims that were up against the gear (these rims will not have the nub on the inside) and drill a tiny hole from the rear to the front throught the center of the rim. Now take the steering knuckles from your Bit and using a small knife or screwdriver, pop the pin out that holds in the wheel. Now put those pins through the rims you just drilled holes in and the put them back into the steering knuckles. Now put on some of the ZipZap rims and tires on that wheel and you are set.
Hope that helps.
There is something strange afoot at the Circle K.
Old 02-21-2003, 11:56 AM
I almost forgot, when you replace the front rims with bigger ones, you will have to dremel out the front wheel wells in order for the car to turn properly. If you don't have a dremel you can either sand it down or maybe trim it down with a knife or file.
Old 02-21-2003, 12:19 PM
MicRoMaN's Avatar
Ok thanks.
Old 02-22-2003, 02:50 PM
Blitzer Sonic
You don't have to take out the pins in the knuckles. You just do a direct knuckle switch.
Old 02-22-2003, 07:03 PM
~SnakeBitRacer~
Same w/back axle. All you need to do is make room by snipping your body or dremel
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 08:53 AM
custom wide rims broke ess supra XMODS Mods and Projects 1 07-18-2005 07:59 PM
New DUB City Rims DriveWRX Bit Char-G Parts and Hop-Ups 20 12-08-2003 09:43 AM
Cool Alloy Rims cj1267 ZipZaps 0 05-09-2003 12:17 AM
