Go Back   TinyRC.com > 1/18 and Larger > Tamiya M-Chassis > Tamiya M-Chassis
Old 05-18-2002, 03:22 AM
PorscheGuy964's Avatar
PorscheGuy964 PorscheGuy964 is offline
M-Chassis Innovator
Send a message via AIM to PorscheGuy964 Send a message via Yahoo to PorscheGuy964
The M-Chassis
Since the M-Chassis forums were just added let me introduce you guys to the M.
The M chassis is a 1/10 scale car that is smaller than almost all 1/10 cars. Tamiya had made this chassis to accomidate the smaller cars in real life so is that it would be true-er to scale. Example if you were to fit a Mini cooper body to one of your normal 1/10 touring cars it would haev to fit the 190mm or 200mm sizes that the 1/10 touring car traditionally use, thus the car would not be a 1/10 scale model of a mini cooper.
There is 5 different M chassis's. The M-01,M-02,M-03,M03L and last but most currant is the M04L.
The M-01 is the oldest of the M-chassis's. It is FWD and uses different body mount locations then the M-03. It also has a different suspension set up. It uses one friction shock for both of the wishbones on the front suspention and the rear. Thus its suspention is not as smooth as having a single shock for eack wheel. The M-01 is also the most delicate the the M's its plastic is weak. It uses a geard "open" differential. This car, the M-01, however is out of production and to some is a collecters item.
The M-02 is RWD. Infact the M-02 is a RWD version of teh M-01 being that its basically turned around and teh rear becomed the front and so on. it still uses the single shock suspention for the front and rear. It also uses a geared "open" differential.What is upgraded is the material. It uses a stronger plastics. This car too as, M-01 counter part, is now discontinued and some, a small some, are now considering the collectors item.
The M-03 is also FWD, infact half of the M-chassis's are front wheel drive and half is rear wheel drive, which I will explan later on. The M-03 is the most currant of the FWD M-chassis's. It uses independent four wheel suspension using friction shocks(as all M-Chassis's do). This car does use a "open" geared Differential. This car is also the most durable of the FWD M's. The M-03 is still in production. I currantly own the M-03 and I must say it is one of teh best handling cars I haev driven. It is almost impossible to make one of these to spin out. I had to try very hard and even when I did it was only 180 degree turn. But of course as with all FWD cars,even 1/1 scale, your tires are going to wear faster than if you were of a differnt Drive train such as RWD.
The M-03L is the same as teh M-03 but its Chassis has a extender in it. This increases the length of teh chassis to accomidate more bodies such as the Suzuki R. This car,although I have not driven one, is said to handle somewhat "clunky" as it is of a longer wheel base so it will not be as nimble as the standard M-03. All of the FWD M-chassis's as with any FWD car will want to understeer.
The last of the M-Chassis's is also the newest. It is the M-04L. This car is slightly longer than the M-03. It is basically a stretched M-03 turned around the same situation withe teh M-01 and M-02 .It has four wheel independant suspension using friction shocks. It also, as with the othe M-chassis's uses an "open" geared differential. This car is the fastest of all the M-chassis's if all were left stock. Although it uses the same motor as the other cars it is geared differntly resulting in a higher top speed. Since it is RWD off the line it is, of course, going to have better acceration than the FWD M-chassis's since the RWD car is going to have better traction off the line. Of course,which is the case of most RWD cars, the M-04L is going to oversteer at times but not to a degree at which is not easily corected allowing a driver of skill to drift the M-04L.
It should be noted that ALL of the M-chassis come with MSC a.k.a. mechanical speed controllers. these are ok if you are going to stay with ethe stock motor. but if you want to get a better motor it is HIGHLY recomend by me and most everyone that you go ahead and just get a ESC a.k.a electronic speed controller.
If anyone has any questions regarding the M-chassis just ask me and I will try and do my best at helping you.
And once again I must thank TinyR/C for adding the M-chassis to thier wonderfull site.
-Thanks
Old 05-18-2002, 11:25 AM
tinyrc's Avatar
tinyrc tinyrc is offline
PorscheGuy964, thanks for the great info, and no problem RE adding it to the site!
Old 05-19-2002, 01:57 AM
323iT's Avatar
323iT 323iT is offline
Send a message via AIM to 323iT
Thumbs up
I'll race you with my mini z
Old 05-20-2002, 06:18 PM
M-Chassis Innovator
cha, and loose....heheh, My M-03 can go 50 MPH what can your Z do?
Old 05-21-2002, 02:03 PM
Hardtrukr's Avatar
Hardtrukr Hardtrukr is offline
I'm The Youngin' of R/C
Send a message via AIM to Hardtrukr
my Brothers RC-10GT can do 54MPH. my nitroquake does a surprising 42MPH! (4x4 and 10.3 lbs.)
Hey Officer, Did You Stop At The Donut Shop On The Way Here?
Old 05-21-2002, 02:20 PM
M-Chassis Innovator
Yea but those are bigger, and powered by nitromethan and are "real" 1/10....The M is only 800 grams and is FWD...HA! lol...
Old 05-22-2002, 02:26 PM
ZGhostDogR8dr ZGhostDogR8dr is offline
Great Breakdown PG964 !
Congrats on the board and keep the cool info coming. 50mph ! Wow ...
Old 06-23-2002, 09:10 PM
tinyrc's Avatar
Just wanted to let you know about this thread over at yourmicro.com that may be of interest:
http://yourmicro.com/forums/showthre...?threadid=1634
Old 06-23-2002, 10:45 PM
M-Chassis Innovator
SWEET! mayeb you can tell some of those guys to come over here...of yea and they do make lots of alloy parts for the M.......
Old 06-25-2002, 12:57 PM
tinyrc's Avatar
PorscheGuy964, you're the M-Chassis expert - sign up on YourMicro.com and recruit them over here!
Micro-T Carbon Fiber Chassis DAMZer Micro-T Parts and Hop-Ups 14 05-20-2010 06:57 AM
Carbon Fiber Chassis WillS Mini-X 22 08-13-2003 07:17 PM
custom chassis production has started ronak26 Bit Char-G / MicroSizers 45 02-24-2003 03:18 AM
Stock chassis warp Mr Freeze Bit Char-G / MicroSizers 0 12-05-2002 11:35 PM
