Old 02-05-2003, 09:12 PM
novastar512's Avatar
novastar512 novastar512 is offline
Subaru WRX Rally X Driver
Question How many times do you multi-charge?
I was wondering if people really multicharge their bits. Even though it may give them a longer run time, it is also proportional to the amount of time spent charging. So do people multi-charge?
R/C Garage 7 "Super New" Bitchar-a Precious Cars 2 - RX-7 1 - Skyline 2 - Lancer 2 - Impreza
Take a look at My Finished Modular Track with pics
Old 02-05-2003, 09:14 PM
noxorc
With my hand raised...
Yes, I do.
but no more than twice, because of time and payoff.
-nox
Old 02-05-2003, 09:27 PM
How long do you get with 1 and 2 charges? Anybody?
Old 02-06-2003, 07:33 AM
BabyKiller's Avatar
hmm with 2 oe 3 i get around 35min but i usally do six charges and run very close to a hour
+ (4.8v)
Old 02-06-2003, 08:41 AM
crazydave's Avatar
Garage Rocker
I used to charge my car 3 times, and get a 15 min runtime. Now I use my volt meter to peak charge, and it charges for about 3min. before the voltage drops. That's aprox. 4-45sec. charges, and I get 20min runtimes w/ a 3.8 motor. I wouldn't charge more than that, as that is getting the battery warm, and after doing this several times, that is the point where the battery has consistly peaked. Any more and you might get longer runtimes at first, but you'll soon see yor performance deteriorate, if your battery even takes a charge. Also I should mention as your batteries in your controller become weak, it takes longer to charge. The times I've given are with fresh batteries. Read my link above for a better understanding.
Also if you charge your batteries more than once, do so at your own risk. The controller is already giving the battery a little more zap than the batteries like. Some batteries wont be able to handle more than 45sec., but if that happens, I say good riddance to that battery.
Filling your batteries to capacity will also make yor car much punchier.
Dave
Crazy Dave's Crazy Car Gallery-It's crazy man, dig it.
Old 02-06-2003, 09:32 AM
nghts's Avatar
nghts nghts is offline
Send a message via Yahoo to nghts
I don't multi charge often...but when I do I find it wears my motor down, or at least it seams thaty wya
AMC Represent
Old 02-06-2003, 02:43 PM
eman1 eman1 is offline
custom title
Send a message via AIM to eman1
2 times
current parts:
auto modellista
4.2 pro
perfection 200mah battery
Pullback wheel mod
Plantraco desktop rover for sale
email me at eman54@optonline.net if you want it
Old 02-06-2003, 04:20 PM
Nathan's Avatar
Nathan Nathan is offline
Bad Driver
Stock battery, 2 times then one after that(i.e. charge, charge, play , charge, play...)
Old 02-06-2003, 04:25 PM
neoGTR22
Nathan... I have the same setup as u. Fairlady with stock batt and rspec motor. Which gear do u use? I've tried all the bit gears but find the Red zipzap gear the best for track purposes.
Multi Charge Box Grasziege Bit Char-G Mods and Projects 16 04-03-2003 02:02 PM
FYI:Motor Works (clone) charging base will charge dual and triple battery setups. Clint Bit Char-G / MicroSizers 0 02-17-2003 04:09 PM
My LXX won't charge Nenox Bit Char-G / MicroSizers 3 11-30-2002 06:16 PM
