02-02-2003, 02:43 PM
<(- -)> <- Yoda
weight reduction
Hey, I went a little crazy with my Xacto knife and my bit last night...here's the results. I'm pretty pleased actually- I use ZZ gears and fullsize ZZ wheels with a clone motor, everything else is stock. This thing goes fast enough to flip when I turn! I can't wait until I can strap my R-Spec in there when it comes. Also, I rerouted the antenna so it goes through the back and I untied the knot (it's kinda hard to see b/c I have a white antenna), this gives a big increase in range.
wooo hooo!
02-02-2003, 02:47 PM
<(- -)> <- Yoda
forgot the pic...
I guess you could say that I removed the "tub" from the tub chassis
wooo hooo!
02-02-2003, 02:59 PM
<(- -)> <- Yoda
here's the bottom
The only problem is you have to make sure that the wires are tucked in, like I didn't in this picture...
wooo hooo!
02-02-2003, 03:00 PM
won't it break in half?
02-02-2003, 03:17 PM
Quack
i agree with BOME, you went just a little more than a little crazy.
02-02-2003, 03:22 PM
<(- -)> <- Yoda
actually, the pastic as enough flex where it's strong enough that it doesn't break. Just make sure that you don't step on it or something.
Also, the clear cover on the top keeps it strong when crashed becuase it takes all the pressure
wooo hooo!
02-02-2003, 03:45 PM
<(- -)> <- Yoda
I just noticed that the car seems to be more balanced as well. I can drive it off dropes about a foot high and it lands flat on its wheels..
wooo hooo!
02-02-2003, 03:49 PM
try reducing the weight even more lol it would be a racing piece of paper ish thing.. haha iono
02-02-2003, 04:38 PM
<(- -)> <- Yoda
lol, maybe I'll make a chassis out of styrofoam...that would be intersting
wooo hooo!
02-02-2003, 06:24 PM
You can't beat it.
Or if you can afford it......... carbon fibre! Put two 150MAH cells in, and watch it fly!
One Ferrari Enzo.
One Mercedes SL600.
1 Mitsubishi Eclipse.
Two 95' Mazda RX7s.
02-02-2003, 08:10 PM
Drift!
Can you tell much of a diference with the reduced weight as far as handling and acceleration is concerned?
All your base are belong to us!
02-02-2003, 08:47 PM
<(- -)> <- Yoda
Yea, it turns a little tighter b/c there's less weight to pull it out and as far as acceleration, it should be faster with less wieght. I can't really tell because it does a burnout every time I press forward (not enough traction).
wooo hooo!
02-02-2003, 08:52 PM
Drift!
sweet, I should try that to my car.
02-03-2003, 01:01 AM
i kno!!!!!!!!!! put rear tomy pullback wheels on that baby! those wheels are wide and have heeella traction!
02-03-2003, 01:55 AM
Eat my Shorts
That. is. some. crazy. moding.
too risky for me...
G0_oD Day.
Bits = AM Set(R34,R32,Supra,Rx-7 shells)
3.0 motor,black rims
