Old 01-23-2003, 02:29 PM
BabyKiller's Avatar
Question charging a nimh
um i cant seem to charge mine with my controller its only running off the little juice it came with?
+ (4.8v)
Old 01-23-2003, 02:35 PM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
that seems to be a statment with a question mark on the end. or were you asking us if we stood over your shoulder while you tried to charge your car? please elaborate.
Old 01-23-2003, 02:49 PM
BabyKiller's Avatar
im trying laymans duelcell mod and its not working i mean sure if i take the battery out and attach it with wires it charges but when it in the car it dosnt work and i cant even get this damn pcb down with the batteries in
+ (4.8v)
Old 01-23-2003, 03:34 PM
hogjowlz's Avatar
you are just gona end up breaking your stuff.
this is how mine was done. i cut out the rear window so the battery sits out of the body half way. you need at least 4v to charge a dual battery car. a stock controller wont do it.
Old 01-23-2003, 03:46 PM
BabyKiller's Avatar
4v charging 2.4v isnt that a little dangerous? atleast that what i heard
+ (4.8v)
Old 01-23-2003, 03:47 PM
BabyKiller's Avatar
anywho sweet ride
+ (4.8v)
Old 01-23-2003, 03:51 PM
hogjowlz's Avatar
dangerous? well either you risk melting a circuit board(i have two and neither have died) or have a car that wont run at all because you only want to do half the mod. how old are you?
Namuna: Ease up bud.
Old 01-23-2003, 03:56 PM
BabyKiller's Avatar
ok im confused now but ive figered out that the light on the controller isnt coming on because my nimh is sucking all the power ok chill please check out laymans duel cell mod to understand what im doing before u go yelling at me
+ (4.8v)
Old 01-23-2003, 03:57 PM
BabyKiller's Avatar
and ive been told by many people the controller charges nimhs fine
+ (4.8v)
Old 01-23-2003, 04:05 PM
hogjowlz's Avatar
look mang not everything on the internet is true. the only thing you can believe is what is in front of you. assume that i am wasting all this time to lie to you so you will blow your little car up. have a nice day.
Old 01-23-2003, 04:21 PM
BabyKiller's Avatar
ok i believe you since your the one who helps me out the most on of my posts
+ (4.8v)
Old 01-23-2003, 04:31 PM
MadMicroDoc's Avatar
MadMicroDoc MadMicroDoc is offline
TinyRC Champion Racer
Unhappy We're in the same boat
I once to had the same problem, i thought i could use the controller mod to get both AA for a good charge for my dual laymans mod. i was damn wrong haha if you do that u might get like half a minute outta the charge,i have to use 4 AA, it works a little for my tri cell laymans but not well enough, thats a future project ! What u should do if you dont have a battery holder and have a KIT racer, crack open the controller and take the 2 AA holde out of that and wire it to the opposite side of the charger( side w/o the red and black wires going into the controller) it usualy has a blue or white wire contecting the - and + side. I snipped those wires and soldered the wires form the KIT racer battery holder to it and theholder to the charging padand VWALLA 4 AA battrey charger ! its ghetto, but hell it works like a charm ! ill send pics if i confused u ha
Old 01-23-2003, 05:04 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
hogjowlz has his means, and if they work for him then so be it.
MY suggestion is that you should NOT go too much over the rated voltage of the pack, when charging
Now, something that should be noted is that a fully charged single nimh battery is usually higher than the rated 1.2v (usually around 1.4v)...Which equates to roughly 2.8v on a dual-mod.
So, if you've got a dual-cell pack...You should keep the voltage at 3.0v charge rate, and as high a current rate (mA) as you feel comfortable with
Old 01-23-2003, 05:26 PM
hogjowlz's Avatar
namuna: i watched an electrical engineer test this with high grade meters and you need at least a 3rd battery to get enough power to charge dual batteries. but anyhow two batteries in the stock controller will not charge a dual battery circuit. if you have a way to do so please explain this.
Old 01-23-2003, 06:10 PM
mcharles13 mcharles13 is offline
Send a message via ICQ to mcharles13
Can anyone clarify this? My car is in the process of being a dual and i need to know if i gotta mod the controller now too.
*currently dead...waiting to be resurrected*
Nimh vs Nicd Vote Xmodracer1 XMODS Parts and Hop-Ups 13 07-06-2004 07:32 PM
Alkaline vs. NiMH (long) georc Bit Science 6 12-27-2002 12:59 PM
NIMH vs NICAD & 4 cell battery holder charging? GiantScale Miscellaneous Discussion 5 12-19-2002 12:09 PM
2 nimh Cell charging xsboost94 Bit Char-G / MicroSizers 1 09-17-2002 12:49 PM
