Old 01-19-2003, 06:46 PM
zombiebaby's Avatar
zombiebaby zombiebaby is offline
drag race king
Question this is a huge problem I,m having
when I put my rear axle in it really loose it look like I have changed it so much that I have worn the nubs that keep it held up in is there anyway 2 fix it or am I screwed
IF I WERE GOD YOU'D SELL YOUR SOUL
Old 01-19-2003, 06:49 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
Send a message via AIM to JTM
glue
Old 01-19-2003, 06:55 PM
zombiebaby's Avatar
drag race king
that would stop the axle from spinning u think?
Old 01-19-2003, 06:57 PM
jei$'s Avatar
jei$ jei$ is offline
ok if the rear axle dont fit n e more, im guessing u r scruedlike they're loose.
i would buy a new one.
JTM, glue dont work if glue happens ,
the rear axle gets stuck
A man who desired nothing is invincible.
Old 01-19-2003, 07:11 PM
Silent_NightR34's Avatar
Got Mini-z?
there was apost somewere saying that if u put a lil pole throught this hole in the back of the chassi(right under the engine under the chassi)it should stay...
Old 01-19-2003, 07:30 PM
JTM's Avatar
JTM JTM is offline
1 4M 70 1337 4U
if you use elmers glue on the bottom of each side, then wait for it to dry and trun it with your fingers itll break loose (doesnt like to stick to smooth metal) and create a nice snug vibration free area.
Old 01-19-2003, 07:36 PM
zombiebaby's Avatar
drag race king
thanks thats a damb good idea I was thinking model glue but elmers would work better
Old 01-19-2003, 07:40 PM
sipsap's Avatar
sipsap sipsap is offline
Race them naked
heat an exacto or razor blade and cut a little slit in front of where the axle snaps in then bend it in to make the hole more snug
Old 01-19-2003, 10:01 PM
Gpbitfreak Gpbitfreak is offline
i read somewhere u can slip a match through the two holes on either side of the axle and it will hold it up.
u might need to cut the match to fit or use a toothpick. if u look i think u will see. its through the hole that u can see the battery through and the other hole on the other side
Old 01-19-2003, 10:05 PM
spikeymike218 spikeymike218 is offline
TinyRC Sith Lord
i was the one who came up with the match idea. heres a link to my post about it:
http://www.tinyrc.com/forums/showthr...le+not+staying
Mine: red S2000 27mhz
Hers: blue subaru WRX 45mhz
Mods:
2.6 motor
8.25:1 gear axle
medium tires/soft stabilizer bars
l.e.d headlights
rare earth magnet
Old 01-19-2003, 10:13 PM
see kids these days are so smart
Huge Problem Please Help!!!!!!!!! NOS man XMODS 7 12-22-2003 02:12 PM
i have a huge dual cell problem. NOS man Bit Char-G / MicroSizers 2 08-22-2003 07:34 PM
sputtering problem with my new zap... Cool Dad ZipZaps 12 06-20-2003 11:05 PM
Huge Problem!!!!! SupraMan017 ZipZaps 4 05-01-2003 12:38 PM
Transmitter problem (picture included) ryanhook Bit Char-G / MicroSizers 11 12-26-2002 08:29 PM
