Old 08-06-2002, 02:24 PM
gsr2k gsr2k is offline
bit char-g bogs like crazy....
Guys my bit char-g bogs like crazy when it goes like just a few feet away from the controller?....think the battery in my controller is already gone or is my POT in the PCB needed to be adjusted better??......
Old 08-06-2002, 03:26 PM
andrzejpw andrzejpw is offline
Not sure why, but the same thing happens on my supra. I've found that holding the antennae up helps a bit. Just touch it with your index finger, and hold it up a tiny bit. It works wonders!
Old 08-06-2002, 03:56 PM
i put in some new batteries, but it still bogs at less then 4 feet from the controller...i think i adjusted the POT in the pcb too much....
Old 08-06-2002, 10:48 PM
any other suggestions??
Old 08-06-2002, 10:52 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
capacitor
by any chance did you take out the capacitor?
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 08-06-2002, 11:35 PM
Capacitor?..Is that the grey looking thing inside the POT?? I did twist it all the way out then put it back in. And tried to adjust it better...It only got a little better.
Old 08-07-2002, 01:20 AM
kbtoyz902's Avatar
kbtoyz902 kbtoyz902 is offline
Bit OG
Send a message via AIM to kbtoyz902
Its this thing inside the control. it was put on newer models, im not sure which but ive seen em on the xanavi and castrol cars. QFM has more info you can look at to help you out.
Old 08-07-2002, 03:35 AM
oh i know what your talking about now...i opened my controller and i dont have that thing installed i guess i got the older verison then...
Old 08-07-2002, 07:21 AM
infinite infinite is offline
you may have turned the POT too much, cause your only suppose to turn it a little bit at a time.
try drilling a little hole in the front of the car near the windsheild and pull the antenna out of there. so it looks like a real cars antenna, this way you get more length, and i'm sure you'll get better range.
so try turning your POT back to the original position and then turning it bit by bit.
no pun intended
good luck
tallest bit char body? Sniper596 Bit Char-G / MicroSizers 2 11-23-2002 09:16 PM
UK bit char g life ......... boring Bit Char Bloke Bit Char-G / MicroSizers 10 11-10-2002 09:10 PM
bit char g - bit char g bike -bullet 00gt Bit Char-G / MicroSizers 1 10-26-2002 04:30 PM
Bit Char G Help superbee Bit Char-G / MicroSizers 3 10-03-2002 05:51 AM
