Old 12-16-2002, 10:59 AM
shocon2k
SUPER HIGH SPEED (3.8, dual bat, speed gears)
Has anyone run a 3.8 with the (I think teal) gears (high speed in the 3 gear and axle set) with dual battery? I have this need for speed, and with 8 points on my license, I kinda have to keep it on the kitchen floor . Are there any adverse affects to the circuitry of running 2.4 volts instead of 1.2? I've done some work with battlebots and I know that you really can't double the voltage through an ESC without melting it (but thats 48 on a 24 volt unit, so maybe the effects aren't as extreme with low voltages)? And also, the steering is done with magnets instead of servomotors, and the motor can probably handle the extra juice.
Anyway, input is appreciated, thanks a lot guys!
And also, would I be able to control this beast?
Old 12-16-2002, 10:38 PM
shocon2k
SWEET LORD! 37 views and not ONE reply? Hello, is there anybody out there? Can anybody hear me? ::forgets rest of lyrics::
Old 12-17-2002, 12:54 AM
shocon2k
All replies are appreciated...I really want to know if I should go get another battery, or if I'll be too fast to control even with my single stock cell.
Old 12-17-2002, 09:18 AM
kombatgti's Avatar
kombatgti kombatgti is offline
Holy Micro RC Batman
i have tiny's 3.8, a single 1.2 mah cell, and I have run it with the speed gears. First off you need _alot_ of room to get it up to full speed, and don't plan on turning cuz you will flip, but a 2 cell 3.8 will scream, I don't think you will run into any problems, you run the risk of burning out the motor if run to fast to long. Just keep it going straight and lemme know how it turns out.
Boston/Worcester area racers e-mail me to set up races!
Old 12-17-2002, 09:57 AM
shocon2k
Thanks, I'll probably get used to the 3.8 and speed gears before doubling my voltage.
That brings me to my second question: can the PCB can handle the extra voltage safely for the long term?
Old 12-17-2002, 10:19 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
supposedly yes.
Old 12-17-2002, 06:29 PM
8ate8 8ate8 is offline
Send a message via AIM to 8ate8
there's been a ton of postings about dual battery mods. use the search button.
Old 12-17-2002, 08:36 PM
shocon2k
Thats kinda why I can't do a search....because for every like 100 about dual batteries, one will apply to my question of reliability. I'm gonna humor you and do a search now, but this thread was created to answer a specific question. Again, thanks in advance for your replies.
Old 12-17-2002, 09:15 PM
eman1 eman1 is offline
custom title
Send a message via AIM to eman1
Re: SUPER HIGH SPEED (3.8, dual bat, speed gears)
if i may ask, what did you do to earn 8 points on your licence??
how long is your licence suspended for, i would guess 6 months or a year.
anyway, good luck with your dual battery 3.8 bit char-g. that think will fly, launch if off a ramp!
Old 12-17-2002, 11:21 PM
shocon2k
In NY 11 points earns you a suspension or revokation, depending on how many times you've reached 11. However, since I was in my first 6 months of having my license, it meant a 60 day suspension and the 6 month period started all over. Points last for 18 months, I get my points off right around Christmas.
BTW it was 92 in a 55, good thing the tropper wasn't a mile up the road, I woulda got hit for 125 in a 55. I was coasting to slow down and he nailed me at 92. 3 mph below the 11 point marker. Still, $275 later, I was riding my bike for 2 months.
A PS--I don't think I'll be doing dual batteries, I just tried it and something got royally screwed. See my latest post on this forum about it.
Old 12-18-2002, 02:40 AM
e_lm_70 e_lm_70 is offline
Got up to 3.6V (42mAh) ... with bottom NiMh cells ... I manage to put 3 in series in the same place of the original 1/3 AAA.
No external batts or extra weight ! No body modification !
I use Bit-ChargG fast gear ... but I found out that the best motor for 3.6V is the 2.2 since it is more efficient then others !
Top speed now it is 11km/h ... vs 9km/h of 3.2 motor !
Accelleration is more impressive ... controll is good since it is a booster bit !
P.S: Top speed isn't too much since the little NiMh can't provide to much current ! At full speed the 4V drop to 2.6V !
e_lm_70
P.S: Using the bottom cell is the best mods for Bits and it is simple reversible, no soldering, and no work on the body !
I charge the car with a OEM controler with 5V DC instead of the 2x1.5V batteries !
Tomy Super Bit Char-g High Speed Set!!! Drag00n Bit Char-G / MicroSizers 3 12-21-2003 11:44 AM
re: tired of flipping on high speed turns? jedclampit Bit Char-G Mods and Projects 18 05-21-2003 04:53 PM
Equation for scale speed and gear ratios. Zephyranthes Bit Char-G / MicroSizers 0 02-10-2003 06:34 PM
auto modellista 2 speed motor work with 3.8? rookillo Bit Char-G / MicroSizers 6 10-16-2002 11:48 PM
Dual Battery and 3.8? ax0n ZipZaps 14 10-09-2002 04:37 PM
