Go Back   TinyRC.com > 1/24 and Smaller > Dynamite Rocket Racer > Dynamite Rocket Racer
Old 12-15-2002, 05:57 PM
Siress Siress is offline
Send a message via AIM to Siress
DTM wheels for the DRR?
Are the foam wheels for the DTM cars the same width and all as the Rocket Racer? Are the ways the wheels mount the same?
Old 12-16-2002, 12:44 AM
avenan avenan is offline
I use DTM SP rims on my DRR. They mount the same -- however, the SP uses flanged bearings up front, where the DRR uses non-flanged. So you'll need 4 3x6 flanged bearings.
They're the same width. I have a set of the type-c rims I dyed black -- they look much nicer than the stock ones IMO.
Old 12-16-2002, 08:31 PM
bigbamboo's Avatar
bigbamboo bigbamboo is offline
INTP
flanged vs. unflanged
Do you know of any difference in flanged v. unflanged? I have found the front RR wheels spin something terrible- very little spin and abrupt stopping.
bigbamboo
Old 12-16-2002, 08:39 PM
One has a flange, one doesn't have a flange?
You can use unflanged bearings, but there's nothing holding them in to the wheel but friction. Corner hard, and its possible the wheel will fly off, leaving a pair of unflanged bearings screwed on to the axle, while your now bearingless wheel goes rolling off. Its possible it'll be fine. I don't know -- I had the proper bearings, so I used them.
As for them spinning poorly, if you're using bushings, that's the problem. If its the bearings, make sure the bearing seats are clean, and the bearings are pressed in well. The outer screw is probably pressing too tightly against the outer bearing, causing it to bind. I had to take a file to the inner portion of one of my axles to make it a little less tight, while still allowing me to put the bolt in tight enough to not spin loose.
Old 12-19-2002, 10:29 PM
How about the tires? I would like to get some aluminum wheels made for the DRR and put some DTM foams on them. Can I do that? Are the tires compatable?
Old 12-19-2002, 11:00 PM
irc irc is offline
The Aktiv wheels and tires fit but you will have to shave the none gear side rim hub a little for the correct width.
" THINK FAST "
Old 12-19-2002, 11:49 PM
ok, here is what I would realy like to know.
If I buy the aluminum wheels for the DRR can I buy a set of foams for the DTM that I can just glue onto the wheels and go. If the foams are larger in width thats no problem.
Old 12-21-2002, 12:51 AM
irc irc is offline
If you are talking about the ABC DTM SP the tires fit with no problem. If your talking about the DTM+4 the fronts will be a little wide.
" THINK FAST "
Old 12-21-2002, 02:46 PM
great
thanks IRC.
Will the abc dtm sp motor mounts fit the DRR slotsurfer Dynamite Rocket Racer 5 03-27-2004 01:02 AM
stuff caught in wheels jbach39 ZipZaps SE 10 10-26-2003 06:38 PM
Micro RS4 wheels bigbamboo Dynamite Rocket Racer Parts and Hop-Ups 0 02-06-2003 06:48 PM
old, warn out DTM SP wheels and tires Siress ABC DTM SP 9 01-08-2003 08:54 PM
dtm better than sp dtmracer ABC DTM SP 7 10-18-2002 05:59 PM
