12-12-2002, 09:23 PM
Batteries
What kind of battery do you use if you want to replace the stock one and how much? What kind of gains do you see if any? Thanks for any help.
12-13-2002, 11:00 AM
really all you will get is higher capacity which means more runtime.
12-13-2002, 01:02 PM
more power!!
yup thats the ma rating,,higher number just means longer runs,,,the stock zz batt is good being ni mh,, with out changing the set up,to acomadate a bigger batt,or more than one.,., i dont see it worth changing..
12-13-2002, 01:17 PM
What It Is To Burn!
I get a run time of about 15-20 minutes with a 150mAh NiMH battery. Plus a bigger battery will supply more power to the car if running a faster motor (dual battery needed for anything higher than a 2.8).
So Tell Me, What's The Price To Pay For Glory?
Bit Char-G Fairlady Z 57Mhz (2-Speed), 3.5 or 3.8, 150mAh NiMH, Blue Gears
MicroSizer RX7 27Mhz (Originally a 27Mhz Celica) (Injured Reserve)
ZipZap Supra (Originally a 49Mhz 911), DKS 2.8, 150 mAh NiMH, Red Gears
12-14-2002, 04:49 PM
How do you put the new battery in? Wont the new one be bigger? What do you have to do? Thanks.
12-14-2002, 05:00 PM
Never Mind. Looked at QFM and found out how to do it.
