Old 12-09-2002, 11:15 PM
BryceOwen BryceOwen is offline
Belt drive?
When I got this little thing, I thought I might be a bit out there as far as mods I wanted to make to it. However, seeing some of the mods that people have done, mine are timid at best.
Has anyone tried making some sort of a belt drive for a Bit? I was thinking maybe using the rubberband from a set of braces for the pullies. My goal is to make it a bit quieter than it is, tho I think most of the noise might be straight from the motor...
Old 12-09-2002, 11:20 PM
VERTiG0 VERTiG0 is offline
hay u guys whats goi-
Send a message via ICQ to VERTiG0
Put some grease on the gears.
Noise = gone.
MTL's Avatar
MTL MTL is offline
www.d1gp.com
Send a message via AIM to MTL
heh neato idea...but maybe the rubberband might come off and get tangled
but try it, yah never know
Old 12-09-2002, 11:35 PM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
If you try to use a rubber band, you will have to turn the motor around to the other side, or just run the motor in reverse to go forwards.
I'm out like the fat kid in dodgeball.
Old 12-09-2002, 11:38 PM
Stridex's Avatar
Stridex Stridex is offline
Chunk
These little motors are picky. I tried the belt drive idea with one of the rubbery tires off my stock ZZ. Too much pressure it wouldn't move and not enough....well it's not enough. It has to be possible, but just wrappin a rubberband is not going to do the trick unfortunaetly. This mod is going to require a real miniature belt with teeth. It's the only way I can think of it getting just the right amount of torque. I still encourage you to try it. Hopefully there was something simple I overlooked. Happens to me all the time
A religious war is like
children fighting over
who has the strongest
imaginary friend.
Old 12-10-2002, 08:10 AM
hogjowlz's Avatar
hogjowlz hogjowlz is offline
i dont know about belts. you would lose a lot of power. i would think metal gears may be better than plastic. someone should take some old watches apart or something.
Xmods _FRONT_ Wheel Drive Daedalusleto XMODS Mods and Projects 7 05-16-2004 09:29 AM
FWD XMOD!! YES! Front Wheel Drive!! MicroRCracer XMODS Parts and Hop-Ups 60 01-14-2004 03:32 PM
PS2/CD-Rom drive. truckian Miscellaneous Discussion 1 11-29-2003 12:47 AM
Belt Drive (a Zipier Zap) xxspeednplayaxx ZipZaps 1 09-03-2003 06:10 PM
belt drive mini x 3series takumi Mini-X 5 03-29-2003 07:58 PM
