Old 12-03-2002, 04:04 PM
Bryan4691's Avatar
Bryan4691 Bryan4691 is offline
Asia-Link Racing
New rims & tires???
Does anyone know where I can purchase new rims and tires for my bit? I am looking for something a little wider than the stock ones. Thanks in advance.
Old 12-03-2002, 09:48 PM
hbarer's Avatar
hbarer hbarer is offline
mogi's godfather
zz rims
if you can get a hold
of a zipzap
the front end parts
drop right in
then you've
got interchangable
hubcaps
if you can get
ahold
of
one
oink
Old 12-03-2002, 09:54 PM
TemjinNeo78's Avatar
Bit Drag Racer
here is how you do it: http://tinyrc.com/forums/showthread....&threadid=4244
and here is an example pic of mine:
Old 12-03-2002, 10:01 PM
blacksabbath070's Avatar
blacksabbath070 blacksabbath070 is offline
IRON MAN OF BIT RACING
yep
yea zipzap wheels work great but they might not be what your looking for because they are not wide but they look cool and it makes you have the full size tire mod heres a picture of mine with the zipzap wheels
MY NEW CUSTOMIZED BIT:
red ae86 with zipzap spoiler
carbon fiber hood
3.8 motor (well, it doesnt want to run now)
qfm springs
back wheels on front and back
8.25:1 gearing
rare earth magnet steering
Old 12-03-2002, 10:02 PM
here:
carbon fiber hood
qfm springs
8.25:1 gearing
Old 12-03-2002, 10:03 PM
Bit Drag Racer
not to mention it is a really easy mod.
Old 12-03-2002, 10:05 PM
Bit Drag Racer
iron man how did the springs fair with the zip zap tires?they fit fine? I am getting mine in, but i wanna make sure that they work.
Old 12-03-2002, 10:40 PM
SPEED's Avatar
SPEED SPEED is offline
SPEED IS GOOD
I've heard of rubbing issues when people put Zip Zap wheels up front. Some say it rubs the Chassis??? Is this true???
SPEED-The state of being in rapid motion
Old 12-03-2002, 10:41 PM
Bit Drag Racer
certain bodies(automodellista set in particular)....long time no see my friend
Old 12-03-2002, 10:46 PM
SPEED's Avatar
SPEED IS GOOD
so no rubbing on the chassis?????
Old 12-03-2002, 10:57 PM
Bit Drag Racer
no rubbing ^.^
Old 12-03-2002, 11:00 PM
DriveWRX's Avatar
DriveWRX DriveWRX is offline
Chassis Rub
Hey Speed,
I tried the ZZ fronts on Bits and yes there is chassis rub.
Check this link for a solution to the problem.
MicroSizers Subaru Impreza WRX
Old 12-03-2002, 11:52 PM
Bit Drag Racer
maybe body run, but there is no chasis rub at all (body rub only wiht the bodies i have said) i know what i am talking about htere is no chasis rub, i ride it around and it works perfectly
Old 12-04-2002, 12:42 AM
alpha1's Avatar
alpha1 alpha1 is offline
Runs with sharp stuff
Doesn't the taller wheel make the center of gravity higher causing more flips?
Old 12-04-2002, 01:08 AM
RidgeRacer's Avatar
RidgeRacer RidgeRacer is offline
Tech-Ninja
I did the Zip Zap mod on LXX juat an hour or so ago. It looked coll, but add the LXX chasis to the rubbing list. Every time I turned the tires would rub in the rear.
I'm going to try a Panther tomorrow and see if it rubs.
Day's goodies and Cheap Foam Tires Jazz32 XMODS Parts and Hop-Ups 5 07-20-2006 12:01 PM
lego tires, xmod rims Marius666 XMODS Mods and Projects 19 04-13-2006 09:53 AM
Found a new set of tires that will fit stock rear bit rims... Driven_out Bit Char-G Mods and Projects 0 02-06-2003 08:26 PM
need new tires and rims for my RR Epochracer34 Dynamite Rocket Racer 9 01-19-2003 09:10 PM
Bit tires vs Microsizers tires Dys70pia Bit Char-G Parts and Hop-Ups 3 12-28-2002 04:34 AM
