12-02-2002, 07:04 AM
Wild-G has Stearing weels ?
Looking from the pics on the net it look like that the Wild has no stearing weels, It look like there is a rear motor stearing system similar to what it is in use on Digi-Q!
Am I right ?
12-02-2002, 03:02 PM
yea it drives pritty much the same way as a digi q but its more controlable because it does go as fast
12-03-2002, 01:22 AM
Bad news
Car must stear with weels not my traction diff !
I will probably don't buy ... or I will need to mod it
12-03-2002, 04:25 PM
i ment to say that it is more controlable then a digi q. the stearing feels just like a normal bit char-g. its alot of fun
12-11-2002, 02:22 PM
it's true - you really don't notice the rear wheel steering. It actually turns pretty tight and without a hitch!
I recommend them. They're really fun...and different from the norm of Bits
______________________________
Automodelista: 3.8, 150mah, spring sus.
Wild-G: Raise Tiger w/3.8@the wheels & 2.2@the plow, 150mah
Lancer EVO: 3.0, 150mah, drift set
Hummer shell: 3.8, 150mah, spring sus.
01-14-2003, 08:15 PM
How does the "rear wheel steering" work?
The WCG has two motors, one for the "gimmick" arm, and one for propulsion - right? Some pictures of the guts would be cool!
01-15-2003, 02:12 PM
It uses magnets.. when you want to turn left or right, magnets pull a metalrod left or right, and it's got a gear which will engage to reduce power to one side.
This is just speculation as I wasn't really looking at the mechanism when I opened up my WCG to solder on a new antenna and install new battery.
