Go Back   TinyRC.com > 1/24 and Smaller > ABC DTM > ABC DTM SP
Old 11-17-2002, 06:37 PM
D.S.I.'s Avatar
D.S.I. D.S.I. is offline
Team HybRidD
Question DTM motor pod
Im trying to setup a speed 300 motor plate using a DTM rear pod
but I dont have a DTM, Anyone knows where I can get the Alu pod alone?
can anyone help me out with dimensions?
www.geocities.com/rodzzo/dims.jpg
speed 300 dimensions
http://www.mabuchi-motor.co.jp/english/cat_files/rk_370sd.html
thanks
Old 11-18-2002, 10:37 AM
gertman's Avatar
gertman gertman is offline
You should be able to buy all the parts needed for the rear pod at horrizon hobbies
-Engineering Manager
Old 11-18-2002, 09:06 PM
arch2b's Avatar
arch2b arch2b is offline
TinyRC & Mini-zRacer Fan
off topic,
had to find tell gertman your gallery has great pictures. the cat, bit and mini z is classic. how did you not scare the cat away.
Old 12-23-2002, 07:40 PM
dtmracer dtmracer is offline
i have the original dtm. horizon dosnt really have much dtm stuff, just the sp stuff. its made of 1- 1.5 mm aluminum. it is 3.5 centimeters inside width.the bend on the bottom that bolts onto the chassis is 2 centimeters from the inside of the back of the motor pod. the motor mount hole is vertical from this tab, 5mm up. the shaft is also 5 mm up, 1.5 mm from the tab. the tab is 5 mm wide but it isnt included in my measurements given
My DTM X4 w/300 nimh saddle packs! microrcracing ABC DTM X4 3 01-04-2003 09:51 PM
ABC DTM X-4, details gertman ABC DTM X4 7 10-21-2002 02:09 AM
dtm better than sp dtmracer ABC DTM SP 7 10-18-2002 06:59 PM
Abc Dtm Oman ABC DTM SP 4 08-25-2002 03:09 AM
Parts too easily broken on DTM? Gearloose ABC DTM SP 3 08-18-2002 02:06 PM
