10-28-2002, 10:14 PM
controlers
have you noticed that there are two differant controllers for the zip zaps? i have i have two different ones there is an older models serial model 60-7007 and the new one is 60-7008 the older one it better i think it has molded in bumpy things in he controll sticks and they stick out farther also for easyier use my new controler is harder to keep on the throtle because my fingers slip and there isnt uch to hold on to. Just wantd to fill you guys in on this i thought it was kinda interestin that they have two different styles or it might just be the kit. the 7007 controlercame with a 49mhz pt cruiser and my 49mhz mustang has the smooth ones. You tell me if you have a different controler.
1999 ford cobra mustang
red moter
red transefer gear
red rear axle
no reverse mod
1995 Mitsubishi Eclips GSX Turbo
NOS motor
red/red grearing
no mods.
10-28-2002, 10:15 PM
any pics?
10-28-2002, 10:26 PM
Join the GNU Generation!
i'd be interested in seeing the new controller...
i have a [n unspecified] number of zz's but they all have the same controller style AFAIK...
i believe that no matter what controller any new zz has, the joystick mod is a must... (i can't use 'em otherwise)...
10-29-2002, 01:31 AM
Bus Driver!
If you dont mind can you read off the FCC ID number of the new one? This would tell if there is any thing different inside.
10-29-2002, 02:39 PM
i will make shure and check the fcc number but i cant get a pick of the sticks because the new one i added some grip to it so my fingers dont slip on it.
red moter
red transefer gear
red rear axle
no reverse mod
NOS motor
red/red grearing
no mods.
10-29-2002, 05:34 PM
hmm, i never knew that. thanks!
~RR~
10-29-2002, 05:45 PM
Bus Driver!
It proabbly is the same designed inside. I think the FCC requires a change only if an electronic componet changes from the sample the test was done on. But they could have changed that also.
10-29-2002, 06:44 PM
4r3 j00 ub3r l337 h4xx0r?
Heres a really bad picture of the new controller, it sticks out about 2-3 millimeters more, and has a roughed up surface on the sticks, its definantly better
Shiggity Shiggity Shwa.
10-29-2002, 06:46 PM
Heres another bad picture, this time comparing the controllers...
10-29-2002, 10:43 PM
Kajoq
what serial numbers do you have on yours. my freind just reported to me tht he has a 60-7005 conttroller.
red moter
red transefer gear
red rear axle
no reverse mod
NOS motor
red/red grearing
no mods.
10-29-2002, 10:46 PM
The code on the recent 27 with the added knobs is 60-7003, The code on the 49 i have without the good knobs is 60-7007... and right now im not runnin to the baesment to grab my knobless 27 to check it
lol
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
painted controlers
kasper01001 |
XMODS |
22 |
12-29-2003 09:56 PM |
