Go Back   TinyRC.com > 1/36 and Smaller > Losi Micro-T / Desert Truck / HIGH Roller > Micro-T Parts and Hop-Ups
Old 12-26-2006, 01:18 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
The Compatible Parts List
Alright folks let's use this thread to track all the compatible parts and pieces we've found that fits the Micro-T. I'll keep this first post updated as new info comes in. Let's start:
Motors
Feigao LPS 5250 brushless motor - 12x22mm 5250kv (Part #1208430S)
Servos
Hitech HS-55 Servo.
Towerpro SG90
ESC
Castle Creations PHX-10 brushless ESC
Castle Creations Mamba 25 Brushless ESC
Novak Spy
Receivers
Spektrum SR3500 Micro
Transmitters
Any 27MHz AM band Tx should work.
Chassis Upgrades
eXo-T Lexan Chassis upgrade: http://www.ripper7racing.com/r7rforu...read.php?t=788
Jrx-Z CF Chassis upgrade: http://www.pro-z.com/jrxz/
E-Clips!...Arrrgh!
- Launched an e-clip into neverland? Try using a staple! LOOK
- Also noted is that the e-clips are the same as the ones used by the Mini-T (Losi Part#LOSB1043. Usually sell for $1.50 in packs of 10!).
Alloy Parts
GPM: http://gpmracing.com.hk/car/page/pop_tm01.asp
Hot Racing: http://www.hot-racing.com/index.cgi?c=234
RC Atomic: http://www.rcatomic.com/main/modules...hp?storyid=226
TheToyz: http://thetoyz.com/cart/thetoyz_cate...0T&action=list
Bodies
Parma: http://www.parmapse.com/Images/aahom...60100_Sell.jpg
BRP: http://brpracing.com/18minit.html
Batteries: Note: Stock batteries are 32.3mm x 20.8mm x 11.7mm
NiMH Batteries:
- Kan 4.8v @ 160maH packs at Cheapbatterypacks.com
http://www.indoorflyer.co.uk/index.a...&productid=186
- GP Batteries: Part:GP16AAAM (1/3AAA size) 1.2v @ 160mah NiMH cells (10.2mm x 14.6mm). Build your own packs (x4)
- GP Batteries: Part:GP11AAAM (1/4AAA size) 1.2v @ 120mah NiMH cells (10.2mm x 10.7mm). Potentially build your own 7.2v 120mah battery.
LiPo Batteries (listed are only Lipos that will fit without any chassis mods):
- Team Losi 7.4v @ 180mah Lipo w/charger Team Losi
- Aero-nuts 180mah 15C Lipo @ Aero-Nuts
- HXT 200mAh 12-20C Lipo @ UnitedHobbies
- Full River 250mah 10c Lipo @ IndoorFlyer (UK Based).
- Micron FP 250mah 12C Lipo (3.7v Cell Part#:m082, 7.4v Pack Part#:m800). This is unconfirmed, but supposedly these batteries will fit the stock battery compartment with only a little finagling. There's also the Micron 230mah 15C Lipo (Part#:m083).
Stock Battery Connectors:
http://www.molex.com/cgi-bin/bv/mol...ucts&Lang=en-US
Part Number: 51006-0200 (Female)
Part Number: 51005-0200 (Male)
Wheels/Tires
Micro RS4 or Xray M18 Rear wheels are a direct slip-on over the wheels/tires of the Micro-T! Check out this picture of a set of RS4 Foams on a Micro-T (not mine):
http://rcbros.com/pop_up_image.asp?s...head/CF7_1.jpg
Misc.
- The suspension springs from an XMods Evo has been reported to work on the Micro-T
...Keep an eye out on this original post as I will be updating it as I find new info and as anyone post info here.
thanks.
Credit
Credit for the information above goes to; crazydave, TheSteve, betty.k and others from bitpimps, yourmicro.com, one18th.com, Ripper7Racing.com, RCGroups and other forums. If I've missed anyone deserving of credit here, please let me know.
Old 12-28-2006, 02:40 PM
Namuna's Avatar
Hulk smash!
Adding the following items to the list:
And making some changes to the layout of the original post.
Old 12-28-2006, 09:50 PM
SCARHARDT SCARHARDT is offline
Exclamation Batteries
Gold Peak 4.8v 160mah NiMh battery pack $11.49
HERE
Old 12-29-2006, 02:26 PM
Namuna's Avatar
Hulk smash!
Higher capacity pack, for slightly less than stock. Nice!
Killer Hobbies is also solid shop. Nice find SCARHARDT. Hope you don't mind I updated your post with more detailed info.
Old 12-30-2006, 09:59 PM
no probs
it is a good find, ive been searching everywhere lol, gf is getting a little peved that im spending too much time on this little machine
and thanks!
Old 12-30-2006, 10:05 PM
Namuna's Avatar
Hulk smash!
Added a quick tip about using staples in place of lost eclips.
Also added about the Micro-T using the same e-clips as the Mini-T.
Old 12-31-2006, 02:17 PM
Slicks
im gonna try and grind down my old set of rubber for slicks, im running on a linoleum floor, so im gonna use some tricks from my slot car days, will post pics asap
Old 01-02-2007, 12:15 AM
Keono Keono is offline
I took some destroyed tires from my Micro-T (it's easy to destroy them on a tight thread carpet) and removed all teh rubber. I then put Foam Tape from Home Depot on the tires and now I have foam tires. so, stock tires+fun+ Home Depot=Foam tires for hardwood floors
Old 01-02-2007, 12:42 AM
HERE
I'm sorry my friend, you got RIPPED OFF.
http://www.cheapbatterypacks.com/mai...er=3&model=419
You can get the 160 MaH 4.8V yadda yadda yadda, for roughly 8 bucks on cheap battery packs.com
Old 01-02-2007, 08:26 AM
Namuna's Avatar
Hulk smash!
Sounds great! What's the part/ticket# of that Foam Tape at Home Depot? And/Or do you have pictures?
Good find on the Kan batts at CBP. CBP also has a good reputation.
Thanks.
Old 01-02-2007, 08:52 PM
hmmm I thought I got it from home depot... It's single adhesive sided foam. I went to home-depot.com and couldn't find it at all... I tried a couple crafts sites as well... I'll keep looking, and if I find it, I'll link it. sry... I bought the stuff a LONG time ago.
Old 01-03-2007, 12:33 AM
LBRC's Avatar
LBRC LBRC is offline
Only problem is that the Cheapbatterypacks.com doesn’t have Micro-T battery connectors, where as the ones from his post do. On the other hand why not get them directly from OnlyBatteryPacks.com instead of resold by Killer hobbies probably with a markup.
Old 01-06-2007, 10:56 AM
3 bucks?
i dont consider that a rip off, especially when it might cost 3 bucks for a connector
Old 01-07-2007, 11:38 PM
sry, I didn't mean to offend. I thought it was a ripoff becuase I auto convert EVERYTHING to deans/micro deans clips right off the bat, and I'm pretty sure CBP does micro deans. as for the foam, I found some in walmart. it's not a tape, it's a sheet. thin, but cheap. $0.89 per sheet. one side is adhesive. I don't know where I got that other stuff. I can't find it anywhere, and I'm all out of it...
I thought of something to make some big foamies for the micro T as well. I'm gonna do it myself as soon as I wear out another set of tires.
http://www.rchobbiesandmore.com/prod...0&cat=0&page=4
Cut these into the right width.
glue/double sided tape the tire, and voila, you got foamies.
Old 01-08-2007, 11:05 PM
Namuna's Avatar
Hulk smash!
Just added "Wheels/Tires" info, the RS4/M18 Rear wheels are a direct slip-on! Sweet!
Stock parts list required to convert a Micro-T to a Micro-Desert Truck arch2b Micro-T Parts and Hop-Ups 0 11-12-2007 08:55 AM
What mini-z parts are compatible with the x-mod? mustang_steve XMODS Parts and Hop-Ups 9 01-18-2004 06:56 PM
List of parts wasuri XMODS Parts and Hop-Ups 1 10-27-2003 09:30 PM
Are Bit Char G parts compatible with Micro mites?? SPEED Bit Char-G / MicroSizers 2 08-20-2002 05:31 PM
