Old 11-08-2006, 02:40 PM
chriskim95 chriskim95 is offline
Send a message via AIM to chriskim95
On my ZipZap Civic, the range sucks
How can I make it be able to go past 1 inch? Also this is 27 mhz.Should I just get an SE? Does the SE have better range? By how much? How long until it gets out of signal?
Might get Xmod EVo if I can do he things I want
Old 11-08-2006, 04:34 PM
zzultimate zzultimate is offline
Send a message via AIM to zzultimate Send a message via MSN to zzultimate
Make sure your antenna is attached to the pcb inside the car. Also try putting in new batts in your controller. Your car sholud go past one inch.
Range for the zz's and zzse's are about the same. My range is about 12 feet.
Xmods:
Old 11-08-2006, 05:51 PM
Oh
I was looking for a micro car with terrific range oh well
Old 11-08-2006, 06:10 PM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
Not going to happen.
You're only providing 2AA worth of juice to the transmitter...Not enough to provide "terrific" range.
...Then again, these are micro cars and not meant to be driven over long ranges either.
Still, something's definitely not right if you're only getting a couple of inches of range...You sure you're not exaggerating a little with having only 1" range? hmmmm?
The micros should have a range of up to 25', but on average 12 to 20 is decent.
Old 12-29-2006, 12:40 PM
Jaem Jaem is offline
A parabolic reflector helps...
I don't actually have a ZZ, but my friend lent me his SE so I could fix it (it's working now), and I wasn't impressed with the range either.
I imagine (haven't tried it yet) that soldering a better antenna onto the car might help, but the simplest thing is probably to make a parabolic reflector for the Tx antenna. Think about it - most of the signal is going off in other directions... the attached file is my pattern - make two and wrap a cardboard strip around it. then cover the inside with aluminum foil and punch the antenna through. the antenna will still work normally for normal range, but as long as the reflector is pointed at the car, it should be able to go at least half as far again, if not more.
zipzap and zipzap se? xmod456 ZipZaps 8 01-24-2005 04:11 PM
-= ZipZap SALE!! =- NitroBurner For Sale/Trade 2 02-11-2003 12:26 PM
Black Honda Civic ZipZap for Sale bill ZipZaps 6 01-06-2003 11:45 PM
poor range? GTR ZipZaps 3 11-18-2002 02:54 PM
ZipZap range d00kie ZipZaps 6 10-03-2002 02:53 PM
