Old 07-02-2006, 04:07 AM
Namuna's Avatar
Namuna Namuna is offline
Hulk smash!
What's a Diff (Differential)?...Here's the answer
Here are some questions answered about Diffs. I'm no super-expert on the subject (so if I have anything wrong, someone who knows better please feel free to correct any errors) but it seems worth mentioning this info for folks who don't know.
1. What's a Diff?
A "Diff" is short for Differential. Here's a picture of one for an XMods Evo (blue alloy)
2. Why is it called a Differential?
Because if you turn one side, the other side turns in the opposite direction. Here's a video I made to demonstrate this:
How a Diff Works
3. What's the purpose for it to be able to turn either side in opposite directions?
The video demonstration from question #2 only demonstrates how each side turns the other side in opposite directions. But when the Diff is actually in use, the Motor gear is driving the diff at the gears (not at the drive shaft that I was turning in the video). In doing this, it allows the 2 sides to turn at different speeds (another reason for it being called "Differntial"). This is useful for going around turns as it provides equal torque to both wheels (even though they might be turning at different speeds).
4. So then what's "Posi-Traction" or "Locking the Diff"?
Posi-Traction (or also called "Locking the Diff") is when you make a modification to the Diff that FORCES BOTH SIDES to turn in the same direction. This is usually achieved by simply using super-glue in the gears that turns either side in opposing directions. Thereby LOCKING the gears in position.
4a. Why the heck would I want to do that???!! Locking the Diff FORCES the diff to spin BOTH wheels equally. To many Off-Roaders this is a MUST mod. Whereas with a standard diff, if 1 wheel gets caught up then the other wheel will just keep spinning and you're basically stuck.
Old 07-02-2006, 09:50 AM
bengali548's Avatar
bengali548 bengali548 is offline
(insert something funny)
wow THANK YOU just one question when you lock the diff how do you take out the pin for mine im using a stock diff on an evo and its hard as hell to take out
Old 07-02-2006, 01:20 PM
silentracer's Avatar
silentracer silentracer is offline
posi traction is lsd, so it does slip and the wheels will move at different rates if the pressure plates are over by the the engine's power. the limited slip is also good for draging because if your rear wheels are pushing with the same force foward then ur gonna go nowhere but foward while in an open diff u may spin out as one tire spins faster cause u to slide the rear end in the other direction. having a locked diff is only good for off roading just like namuna stated. locking ur cars diff would not be good for racing because when u try to turn ur wheels need to move at diff speeds and ur locked diff will fight against that motion. the result would be major understeer or ur wheels will force loss of traction causing u to spin out. hope i helped someone, just some info i know
Old 07-02-2006, 01:44 PM
bengali548's Avatar
k i didnt take out the pin but i locked it but no im wondeirng that if i get a awd kit shud i lock that diff as well.
what im worried about is that becuase i want to drift my speed might suffer
should i lock my front diff bengali548 XMODS Parts and Hop-Ups 2 08-01-2006 08:43 PM
The Ball Differential: LSD, USD, or LGD? Turnination Guy XMODS Parts and Hop-Ups 0 02-03-2005 01:29 AM
Ball Diff Behavior vejur79 XMODS 4 11-04-2003 05:51 PM
Diff ... Diff e_lm_70 Epoch RC1/43 2 11-26-2002 05:29 AM
diff handling with diff bodies? kombatgti Bit Char-G / MicroSizers 2 11-07-2002 10:20 PM
