Old 05-22-2006, 07:02 PM
hotmod252 hotmod252 is offline
help no power
for some reason I cant use the purple motor or the orange upgrade motor in my new zip zap. I just got it today its the dodge viper
Old 05-22-2006, 09:20 PM
Azimov's Avatar
Azimov Azimov is offline
I process, therefore I am
I'm not sure which motor connfiguration came in your Viper, but I suspect it's the new square endbell motors and the new heatsink with the extra tab. It could be that your upgrade motors are old tech and the contact points don't mesh properly. If this is the case, you could try hard wiring them in or otherwise altering the old motors to work in the newer chassis.
With the added power that the newer cars have, the purple motor should scream if you can get it hooked up properly.
Old 05-27-2006, 08:29 AM
thanks for responding but the viper came with the the blue gears and red motor with the circle on the bottom but i found some even older motors and they seem to work great other than a little whinning
Old 05-27-2006, 02:10 PM
Jazz32
Are you using the motor clip that has that extra piece that slides underneath the motor? If you don't switch motor clips, they don't work.
Making a power supply out of a PC power supply unit arch2b Miscellaneous Discussion 2 06-05-2005 07:53 AM
Charge combat digiq with a DC power supply.(without 4 AA batteries) vantzeng Combat Digi Q 4 02-09-2004 07:24 AM
question about a peak charger. (regards to power supply) Clint Miscellaneous Discussion 1 03-06-2003 10:31 AM
need more power CrazeeBoutMinis Bit Char-G Mods and Projects 4 09-15-2002 11:09 PM
