Old 03-22-2006, 04:45 PM
Steve's Avatar
Steve Steve is offline
zipped up tight!
Project Offroad
Started modding an SE for offroad use. The rear end now has suspension with LOTS of throw, and it articulates as well. It was pretty simple, the trick being a plastic hinge designed for airplane(?) use. Now that the general concept is working, I'm toying with the idea of side springs to buffer the articulation. Then comes the front end...yikes!
Steve's Avatar
zipped up tight!
close up
Old 03-22-2006, 04:46 PM
Steve's Avatar
zipped up tight!
susp1
Old 03-22-2006, 04:47 PM
Steve's Avatar
zipped up tight!
susp2
Steve's Avatar
zipped up tight!
art
Old 03-23-2006, 07:45 AM
frizzen frizzen is offline
Tool User
How about some more info on that hinge?
Man, that takes the Dirty Bit suspension to a whole new level!!!
Old 03-23-2006, 12:06 PM
Steve's Avatar
zipped up tight!
hinge
DU-BRO Nylon Hinge. Did a quick search and came up with the following link.
http://www.shopatron.com/product/pro...d=DUB119/101.0
Old 03-27-2006, 03:11 PM
Steve's Avatar
zipped up tight!
font
some progress...
Old 03-27-2006, 04:44 PM
Tool User
*struggles to pry my jaw off the floor*
That is so wicked!!!!!!!!!!!
Old 04-02-2006, 05:31 PM
zzultimate zzultimate is offline
Send a message via AIM to zzultimate Send a message via MSN to zzultimate
WOW! amazing! Can you tell us a little about the front end?
Xmods:
Old 04-03-2006, 01:58 PM
Steve's Avatar
zipped up tight!
The A-arms are just spring steel, the shock towers brass. It needs much smaller springs, but the travel is such that the springs need to be really long...can't find any yet. The steering servo was turned upright to allow centering of the battery, However, now there is no place for the PCB. The steering servo has an arm on it now, ready for a tie rod and ball end setup.
This car and project will soon be in the hands of Jazz32, hopefully he'll continue to tinker.
Old 04-03-2006, 03:19 PM
Jazz32
I will continue to tinker... this length of customization is something I have not done in the past, but I look forward to it.
Old 04-03-2006, 03:55 PM
Snake Mod Snake Mod is offline
Send a message via MSN to Snake Mod
Exclamation Tinker
Hope you can finish Steve's magnificent job Jazz32. IF you do use a pcb, use a motorworks one, it allows for more torque so you can give a very powerful motor and it can take it.
MOTORWORKS
[color=green]
Old 04-03-2006, 05:14 PM
Jazz32
He's already set up the front steering with the gear box from an SE. i think part of the offroading portion was to use digital controls. I'm looking forward to getting the stuff and seeing what I can do!! With motorworks, remember, i only have 2 right now w/o a remote to run either. Though I still haven't tried all the types of remotes i have.
I'm confident that with my soldering skills, I will be able to do some fet mods once i get some $$$ to buy some. Who knows... maybe i'll use a zzmt or a SS motor with this thing.
Old 04-04-2006, 03:07 AM
Tool User
An SE with a DC mod (and Fets if you're really crazy) should be more than capible of smoking a Motorworks, plus with the 6 steps each way it'll be a lot easier to control offroad than the 1 step each way of a Motorworks.
And if you want more torque, just toss in a ZZ-M motor instead of the standard ZZ motors. Give you enough torque that you could get by with Direct drive or like a Kitt Racer gearing.
Project VIPER (DEAD) New project S12Driver XMODS Mods and Projects 3 04-08-2008 01:44 AM
Project Bit-X Pietak440 Bit Char-G Mods and Projects 81 07-14-2005 02:15 AM
my 1/24 offroad project sawhit4 Other Tiny RCs 2 11-10-2004 04:37 PM
My First "Big" Project wasuri Bit Char-G Mods and Projects 2 11-30-2003 04:58 PM
Project Ideas sokalxballa XMODS Mods and Projects 0 11-23-2003 09:21 PM
