Old 02-02-2005, 04:23 PM
broke ess supra broke ess supra is offline
bad motor winding and balancing
I've rewound a few different stage 2 armatures with 30 gauge wire like 4 different times and i still haven't been able to get as good torque as the stock stage 2 motor...
I actually made a 55 turn motor and its not as good as the 49 turn stage 2 motor....
Is there a trick in winding the motors to make it have more torque? (besides the number of turns and size wire)
...ALSO...
i read that the 130sm armature is balanced and if you look at the pictures on you'll see some sort of epoxy, what do you use to see which side is lighter/off balance on the armature?
