Old 01-11-2005, 11:43 PM
sporttracguy sporttracguy is offline
Aftermarket bodies???
I'm curious how many of you have installed an aftermarket body to your monster. I went looking the other day for something other than radio shack brand that i could retrofit but didnt have much luck. I took the stock "bigfoot" body with me to get basic size idea but couldnt find much in the way of a good fit. Has anyone found a good source for an aftermarket body? just looking for ideas
sporttracguy
Old 01-12-2005, 08:26 AM
ynad's Avatar
ynad ynad is offline
try slot cars may be found @ lhs
http://maxf.net/~ynad/zx/web%20BM%20...d/datsun01.jpg
if pic doesn't show try url
Old 01-13-2005, 12:56 AM
I found a metal(hotwheels style) body and i think i can retrofit it to work but im worried about the weight. Do you think that a metal body would slow it down alot or would it be hard to tell?
Sporttracguy
Old 01-13-2005, 09:24 AM
ynad's Avatar
" Do you think that a metal body would slow it down alot or would it be hard to tell?"
Metal body is a lot havier than plastic one.
aproximate weight of the ZZSE with the body is about 30g
the ZZ shell is about 10g
the metal body about 35g
bottom line, die-cast body will slow it down.
Old 01-13-2005, 12:25 PM
well i tried a metal body last night and after alot of grinding and removing the metal under carrage,, and a few small modifications i was able to get it to fit. Its a little smaller than the stock body but it does work.. as far as slowing it down and such i didnt notice much of any difference,, the only thing i did notice is that the run time was a bit less,,, i may keep it i may not,, just thought i would get that info out.
here are some pics.
( i own a sport trac so its only fitting)
Old 01-13-2005, 12:26 PM
says i need text to post a picture,, i suppose this will work
just one more after this
Old 01-13-2005, 12:27 PM
oddly enough the orange gears match quite well,, i just wish i could get the body to sit down a little lower,, problem is the bed sinks down and stops it,, all well
Old 01-13-2005, 03:49 PM
ynad's Avatar
looks very nice. more like the real thing. shoud be handling
better.
btw my bad on the weight statments. i was talking about
zip zap se.
as far as monster goes. it's got plenty of power to run
with that body but wears out quicker. that's the weight.
i like my monster jumps so i went with a lighter body.
picture gallery
Old 01-13-2005, 05:14 PM
hey Ynad, what kind of R/C car is that little yellow truck?
Old 01-13-2005, 05:58 PM
ynad's Avatar
HO scale slot car on nikko chassis.
Old 01-13-2005, 10:07 PM
what kind of nikko chassis? is it better than the ZZMT? how much and where can i get one?
Thanks
Sporttracguy
Old 01-14-2005, 01:10 AM
i took the body off and ground down some more metal and removed the clear cover on the top and now ive been able to lower the body down to that lower horizontal line,, looks much better,, ill try and get pics later,,, i also removed the bump stops on the shocks and was able to get twice the travel in the front,, now if i could only find some weaker springs,, maybe ball point pen springs or something
sporttracguy
Old 01-14-2005, 06:28 AM
ynad's Avatar
H-E-L-L NO. it's not better. can be fond at toy store
KB toys, WALmart,etc. about $12. it's not all that bad,
but no comparison to monster. it's got magnet steering and it's RWD.
if you removed plastic cover, i would sudgest some electric tape or thin plastic to cover pcb away from dust. should
improve your weight ratio.
How are you mounting your aftermarket bodies? sporttracguy XMODS 0 10-16-2004 12:08 AM
Looking for some Smart & Puegeot bodies. Blamminator Bit Char-G / MicroSizers 4 02-14-2003 09:35 PM
7 bodies up for trade and a hotwheel kit racer zombiebaby For Sale/Trade 22 02-08-2003 11:03 PM
Epoch spec 2 bodies coming soon!!!!! Epochracer34 Epoch RC1/43 8 02-04-2003 09:15 AM
Looking For These Bodies shanly For Sale/Trade 14 01-29-2003 04:38 PM
