Old 08-10-2004, 08:26 PM
jamgunner jamgunner is offline
Wannabe TinyRC Pro
Send a message via AIM to jamgunner
new car, slight problem
just picked up an orange gto with date code 02A04. much, much better than my original white savanah. hardly any studdering, equal steps each way and it even seems faster. only problem im having is that when i turn to the right (even the slightest) i spinout. anyclues as to whats going on?? ive been messing with tire combos but if it was the tires i figured it would be doing this each direction... but its only when turning right. thanks in advance.
heres a pic:
Old 08-10-2004, 08:40 PM
Jtskty Jtskty is offline
Master Debater
Send a message via AIM to Jtskty
Your tire might be loose on the axle. Try to spin both rear tires in oppisite directions. Tell me if they do it. If not, it is just that it turns better to the right then the left and that is why I dont like se's.
Old 08-10-2004, 09:14 PM
Wannabe TinyRC Pro
rear axle is fine (though i have had that problem before on the the orignal zzs). now that i started looking around better its becuase the front right wheel will not spin freely like the left. hopefuly i can work it over with a pair of tweezers... taking the pin out will be the last thing i do seeing that it looks like a pain to do.
Old 08-10-2004, 10:43 PM
richh richh is offline
that sounds like it might be it. another thing to check is how the front wheels are sitting. i had a torino where one of the front wheels was barely making contact with the ground.
Old 08-10-2004, 11:57 PM
Wannabe TinyRC Pro
yea ive pretty much got it cleaned out. i have a set of tweezers that are almost need thin so they work perfect. one thing i noticed about the updated se's is that there is very little "play" in the front wheels compared to the older ones, hence i dont wanna remove the pins and mess anything up.
edit:
i just figured out that its becuase the left wheel is barly touching the ground.... i guess ill just modify the right side with a spacer of some sort to limit the suspension from reaching its full drop and hopefuly making the left side touch the ground.
edit edit:
the front of the chassis is crazy bent , i guess only fix is an exchange, oh how i like dealing with rs people on exchanges...
Old 08-13-2004, 06:20 PM
Wannabe TinyRC Pro
haha, exchanged for a new one. guess what? the new one is just as bad if not worse. awsome! i think im starting to remmber why i stoped messing with these things...
Old 08-14-2004, 11:04 AM
DailyDriver
big boy toy
.....i think it is very funny, how they marketed these cars ages 8 and up or smething like that, yet they are so darn expensive when you stat mucking with them.......only because of what i think is the lemon factor, as where the car out of the box is defective. I have noticed many how to docs on various things and wondered why no doc has outlined a "lemon factor" describing items to look for 'out of the box', if the car doesn't perform to a few minor standards out of the box for myself i strip it for parts and return it. range,sputtering, steering balance usually in ZZ's tends to be strong on one side when turning right so there is alot of rigfht countersteer adjustment on the bottom of the car but one in a hundred will have been built well and is close to beeing straight up the middle and drives straight, often wonder if someone just slapped it together but they must go through some form of QC and alignment test, before pkg'ing, there are good ones and lots of bad ones!
Old 08-14-2004, 01:56 PM
Sawblade's Avatar
Sawblade Sawblade is offline
Wheeeelie!
I doubt there is a human involved in any of the assembly unless they're working for $1 per day in china or somewhere similar.
-=Sawblade=-
Wheelie poppin' Red ZZ F-150 - Rear soft microsizers tires, Front hard tires, beer keg tri-cell mod, anti-roll bars, wheelie bars, 1/8" body drop, rare earth steering magnet, dual return springs, steering stabilizer bar and spring suspension, 28K Orange ZZ motor, Red 12:1 gears, 22ga power wires, heatshrinked antenna wire, .
Old 08-14-2004, 07:54 PM
Wannabe TinyRC Pro
yea i understand that needs to be considered. im in no way trying to bash/flame rs and for 15 bucks its hard to argue. they could just be so much better if there was just a tad of quality control...
Old 08-16-2004, 08:37 AM
kvik369 kvik369 is offline
I'm not defending RS cause some of the cars are "lemons" but part of the "lemon factor" is people returning cars once they've "damaged or stripped" it themselves. Some RS's do try and resell them.
K.I.S.S.
Old 08-16-2004, 06:12 PM
Wannabe TinyRC Pro
now that you mention that, some of the black stuff was already removed from some of the things on the board.... wtf??? regardless, im just gonna try to bend this one back in shape and cut my losses.
Old 08-29-2004, 09:44 PM
Twenty-Se7en's Avatar
Twenty-Se7en Twenty-Se7en is offline
I still find it really sad ... the factor of cars that come from the store are defective is insane... every second person on the forum is bitching about how they brough home their new zip and it's busted...
||| It does not matter if you win or lose. It only matters if I do. |||
Unequal Right and Left Turning Radius Fix backtrack9 XMODS Mods and Projects 20 10-02-2004 02:32 AM
Steering Range Fix: Mod the Tierod ikinari XMODS 28 03-31-2004 11:50 AM
Intermittent problem. marc_w Bit Char-G / MicroSizers 7 03-07-2003 01:33 PM
anothner problem another car anthonyb45 Bit Char-G / MicroSizers 1 12-04-2002 12:37 AM
Charger Problem snakeman65 Bit Char-G / MicroSizers 10 10-31-2002 04:35 AM
