Old 06-17-2004, 11:14 PM
bluemonster bluemonster is offline
Broken steering wires
I accidentally broke two of the tiny red wires leading from the PCB to the steering magnets.
Are these repairable, and does someone have high quality pics showing which ones go where?
Old 06-22-2004, 08:22 PM
spamman spamman is offline
Send a message via ICQ to spamman
carefully look through the forum... i know there are pics somewhere. It's a bit tricky, but i've repaired them numerous times. You just need a soldering iron.
Old 06-29-2004, 12:00 AM
Sleeping911 Sleeping911 is offline
The Pcb is Labelled
If you carefully look at the pcb where the copper wires remaining are soldered you will see that one wire is soldered to location marked L for left beside that two wires are soldered to battery negative terminals ( usually a bigger blob joining two pads together ) and the next spot over should say R for right resoldering them is rather easy. and as far as making sure which one is which if both are off the left or right side i have noticed it doesnt matter which one one goes where just have to be L + and B - i believe.
steering wires broken :( -=CrAnSwIcK=- Bit Char-G / MicroSizers 3 12-15-2003 07:09 AM
i need a tub chassis with the wires for steering on it will trade parts for it ronak26 For Sale/Trade 1 01-18-2003 08:11 PM
Steering Wires Broken funkymonkey Bit Char-G / MicroSizers 6 01-14-2003 11:00 AM
Steering wires BLWNSTNG ZipZaps 0 11-03-2002 12:46 AM
