Old 05-18-2004, 07:51 PM
micro kid's Avatar
micro kid micro kid is offline
Do you getto dremel?
Slightly annoyed force
i want to build a micro mad force it will be front and rear susp with the steering end of a bit chassis will be the front "axel" and the motor end will be the rear with a 2 link setup and a vertical plate chassis with a dual cell dont know what ill do for the body but my RX7 truck may be getting a ride for a while at least until i get a BB to make into a truck
racing on pavement is for wussies.
Old 05-19-2004, 03:22 PM
micro kid's Avatar
i need a good way to make shocks with pivots at both ends if anyone has ideas
Old 06-25-2004, 06:34 PM
Racer9's Avatar
Racer9 Racer9 is offline
Tiny RC Pro
use flat palstic strips like lexan that is pretty thin so the weight of it makes it flex a bit (no pun intended) and use them for springs as well as those plastic thingys like on the real Mad Force
K'NEX Mad Force Racer9 Miscellaneous Discussion 14 07-14-2004 03:36 PM
Annoyed With Tiny Rc !!!! tarnjit Miscellaneous Discussion 5 12-04-2002 05:38 PM
