Old 10-12-2002, 02:17 AM
JediYoda56 JediYoda56 is offline
Send a message via Yahoo to JediYoda56
Why does graphite do?
Hello,
I am been hearing of peopel using graphite on there zz/bits. What does it do? I think it is for lubrication but on what? Thanks
Old 10-12-2002, 04:58 AM
SlackerZ's Avatar
SlackerZ SlackerZ is offline
The graphite is to lube the gear on the axle and the small "slip on gear" that meshes with the motor's gear. Supposedly it will quite the chattering of the zz's transmission and prevent excessive wear on parts...but zip parts are cheap enough I think I wouldn't bother applying the powder graphite (whose metalic properties aren't healthy for the pcb or motor).
-SlackerZ
"Did I.Q. 's just drop sharply while I was away?"- Ripley
Old 10-12-2002, 09:00 PM
Ah so there are no speed beenfits to doing this?
Old 10-13-2002, 01:54 AM
Mattydiah's Avatar
Mattydiah Mattydiah is offline
Attack of the Ugly Rocket
There may be slight speed benefits. The major benefit is just in the form of less friction/longer battery life and reduced noise.
Check out the ZIPFAQ!!
I drive an Auldey, because it shouldnt cost you your first born for a 55MPH R/C car.
Old 10-13-2002, 02:25 AM
Cool, then if I wanted to use this stuff what exactly would I be looking for in the store?
Old 10-13-2002, 03:15 AM
Mattydiah's Avatar
Powdered graphite, not liquid graphite.
grease vs. graphite keith92 XMODS Parts and Hop-Ups 14 11-01-2006 07:26 PM
Bearingless Graphite Driveshaft polyesterhat XMODS Parts and Hop-Ups 20 04-14-2004 10:35 PM
Graphite _revhards13 XMODS 2 10-21-2003 07:16 PM
graphite lube? togunter Bit Char-G / MicroSizers 4 10-30-2002 04:19 PM
A little tip for slightly more speed and a lot more longevity Mattydiah ZipZaps 3 10-07-2002 07:12 PM
