Old 02-27-2004, 05:13 PM
350z-zz 350z-zz is offline
Exclamation drifting on tile
i have a couple mini rc cars and i can get the back to slide out on all of them except this xmod...the back tires seem to just grip too much on the tile and when i try to drift the back just bouces up and down as it tries to slide. Tape is too slippery and these tires are too grippy....the only thing i can think of is maybe getting the foam tire upgrade....however im not sure how smooth the foam is and will it slide on tile? Please share any ideas on how i can get my xmod to drift on tile. thnx in advance.
Old 02-27-2004, 05:47 PM
xmodsman's Avatar
xmodsman xmodsman is offline
Send a message via AIM to xmodsman
no it will just bounce
the lesson learned from this post is ..........................tile suchs for xmods
blue RSX
wild silver body kit
stage 2 drift motor
5th cell mod
soft springs front
hard back
3.5 steering
custom plastic skidplate
white rims
metal lugnuts
mini-z tires
and custom painted chasis
Old 02-27-2004, 06:45 PM
duwain
do you have the tire upgrade, because i couldnt gather that from your post. my friend has tile and i can get the back to slide out no problem with my hard treads.
Old 02-27-2004, 07:02 PM
meteoraclown meteoraclown is offline
what are you usin to wet the tile. i use lysol (i'm usually on the toilet when i drift). just make sure the body is off when you use lysol other wise it will splash all over the inside. almost broke mine like that.
Old 02-27-2004, 07:46 PM
no i dont have tire upgrade...right now im just running an SB hybrid with stock wheels/tires
Old 02-27-2004, 08:54 PM
spinitsidewayz!'s Avatar
spinitsidewayz! spinitsidewayz! is offline
boro dori style RC
tile is too grippy and not good for losing traction. even if you do get the back end to slide out ur rear wheels can stick to the transitions and send the car pointing in the other direction or ur car will just flip over lol
r34 - rwd
r34 - awd
dd4 - fwd
Old 02-29-2004, 07:21 PM
well i went ahead and gave it a try. I bought the Foam tire upgrade and all i can say is wow. It worked just as i thought it would. It provided much more grip then tape and some less then the normal tires. Drifiting is easy and my car no longer bouces along on turns, it never flips either. I guess my tiles are a special case scenario but the foam tires really solved my problem.
Just thought i would share,
350
Drifting explained steelo Miscellaneous Discussion 5 07-14-2007 07:35 AM
A simple guide to drifting (WIP) micro-rc-guy XMODS 0 02-06-2007 04:20 AM
Tile drifting? duwain XMODS 6 12-26-2003 10:09 PM
duall cells for drifting boho Bit Char-G / MicroSizers 10 07-14-2003 08:37 AM
Algebra HELP!!!! Tims tile trial XeroGT-R Miscellaneous Discussion 7 03-22-2003 04:16 PM
