hey guys... i have been fiddling with my fet design and found out that you dont need to use both fets to run you motor... i will post the schematic when i have done more testing with this set up... so far everything has been going smooth, i just have to see if the one stock fet holds up... oh and by the way, im not using the one fet to signal the + wire to the motor only the -
