Old 02-19-2004, 10:28 PM
newbitowner's Avatar
newbitowner newbitowner is offline
what is the difference between the white and red gears?
all I know is white is gears and red is bearings...which does what?
thanks
G35 rolling chassis
H2 rolling chassis
Cobra,rolling chassis
red Supra SOLD
65' Mustang...SOLD
Corvette... SOLD
WRX...SOLD
blue Civic...SOLD
Old 02-19-2004, 11:19 PM
RC 2NR RC 2NR is offline
TinyRC XModder
In the AWD kit you'll get two red gears; one is the regular gear type (a.k.a. an open differential), the other is the ball bearing type.
Both allow different wheels to spin at diffrent rates (hence the name differential).
The open differential: Applies the same amount of torque to each wheel.
The ball bearing differential: (When used in the back w/ AWD) When one wheel slips, it allows more torque to be transferred to the non-slipping front wheels...thats why you get so much understeer.
Check out my Fully adjustable plate-type LSD Mod...it is very nice for drifting and IMO, much better than the ball bearing diff.
For Sale:
|XMod :: Black Supra|
-4/5/6 Cell Mod
-Rayovac IC-3's
-Body kit
-Wheel & Tire upgrade
-All Wheel Drive Kit
-Ball Bearing Upgrade
[url]
Jada Upgrade Help! Xmodracer1 Other Tiny RCs 20 09-19-2005 10:30 PM
Differential Difference rssjib XMODS 5 05-22-2004 11:02 PM
Diagram of the Rear Differental Gear YeLLoW GT-R R34 XMODS 7 11-03-2003 10:35 PM
Red white and blue rally car ml22 Bit Char-G / MicroSizers 9 02-24-2003 01:58 PM
